[Salome] Viscous layers with combined thickness greater than background mesh cell crashes |
May 17, 2021, 10:59 |
Mike Worth
Rep Power: 6 |
I'm trying to use salome to mesh a geometry that requires very fine surface layers. Working away from the surface I'd like a geometric progression of layer thicknesses to smoothly transition to a relatively coarse background mesh. I'm going for quad-dominated, and I think that the only algorithm suitable is netgen (although I'm happy to be corrected on this if something else works better).
As far as I can tell the viscous layer node only really works when pushing in the 'bulk mesh' by less than about one mesh cell - any more and it all goes horribly wrong. I've already played with all the options I can find to no avail. Alternatively I'll happily do the layers manually then stitch together the two meshes, but I can't work out how to get a curve offset from my existing one normal to it all along. The original curve I've brought in as a large list of points then joined with a curve. If anyone could show me a way to do that it'd be equally useful. Many thanks, Mike |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
[snappyHexMesh] Collapsing Layers | Tim_Simon | OpenFOAM Meshing & Mesh Conversion | 5 | August 2, 2015 22:51 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
