[blockMesh] Can you use fillets or chamfers in OpenFoam? |
June 22, 2021, 15:18 |
CA
I am creating an impinging jet reactor in openFoam using blockMesh & m4. I am running into the issue of my two cylindrical inlets meeting up with my cylindrical main chamber. The easy solution would be too try and extend the end of the inlets to fit the chamber curved edge, but I am not confident in this methods accuracy for results. Does anyone know if you can create chamfers or fillets in blockMesh/m4 in order to remove sharp edges from a geometry?
June 23, 2021, 13:48 |
Mark Olesen
Rep Power: 40 |
No, nothing like that in blockMesh
July 2, 2021, 20:58 |
Claudio Boezio
Rep Power: 7 |
There might be a way to do this with curved edges and/or projecting surfaces in blockMesh. If you could provide me with a picture of the geometry and how it should look like I could give you a more definite answer.
openfoam blockmesh m4 |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
OpenFOAM Foundation releases OpenFOAMŪ 3.0.0 | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 1 | November 7, 2015 15:16 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
OpenFOAM Foundation Releases OpenFOAM v2.3.0 | opencfd | OpenFOAM Announcements from OpenFOAM Foundation | 3 | December 23, 2014 03:43 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
