[blockMesh] Parallel meshing strategy of a (very) simple case |
September 7, 2021, 11:54 |
Thibault XAVIER
Hi all !
It's the first time for me on the forum. I have a quite simple problem to solve. I would like to set up a simple OpenFOAM case described by a cube. But I need to : - 1* have a linear mesh refinement in one direction (as the simpleGrading option of blockMesh could do) - 2* create a huge case with a billion of element, supposed to be ran on supercomputer. My problem : the usual workflow (blockMesh, decomposePar) could work by using fat node on supercomputer, but can take hours and hours to perform, and sometimes hit the allowed job-time limit of supercomputer. What would be your strategy if you wanted to perform this "simple" case set-up in parallel ? I though about creating coarse mesh, decompose it and then refine it using refineMesh, but it seems i can't control the mesh grading the way i would like (condition 1*). (Extra-bonus question : is it mandatory to have a repertory for each MPI-process ?) Thanks for your great help ! Thibault |
September 9, 2021, 05:56 |
Cyrille Bonamy
Rep Power: 11 |
Hi Thibault,
Have you tried the following command? mpirun -np XXX redistributePar -decompose -parallel doc : https://www.openfoam.com/documentati...-parallel.html |
hpc cluster, mesh, openfoam, parallel |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
Problem running movingCylinders case in parallel with foam-extend-3.1 | mhkenergy | OpenFOAM Running, Solving & CFD | 5 | March 3, 2017 05:20 |
implementation of mapFields into parallel transient case | simpomann | OpenFOAM Pre-Processing | 4 | August 2, 2016 04:41 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
