[Other] Converting mesh from Fluent 21.1
Old   October 18, 2021, 11:41
Default Converting mesh from Fluent 21.1
xuegy is on a distinguished road
Hello all,
I'm converting a fluent polyhedra mesh to OpenFOAM. I'm sure that fluent3DMeshToFoam works with Fluent 17.1 .cas file.
Recently we have upgraded to ANSYS 2021 R1 and now fluent can only export to .cas.h5 or .cas.gz and none of them can be recognized by OpenFOAM.
I even tried to use TUI with no luck
/file> binary-legacy-files
Write binary files? [yes] no
/file> write-case
Anyone knows if there's a workaround? Thanks.
xuegy is offline   Reply With Quote
Old   October 18, 2021, 12:50
Domenico Lahaye
dlahaye is on a distinguished road
Proceed in two steps:
(1/2): gunzip your-file.cas.gz
(2/2): apply previous to your-file.cas
dlahaye is offline   Reply With Quote
Old   October 18, 2021, 12:56
Still doesn't work. However the unzipped .cas file can be opened by Paraview.
Old   June 23, 2022, 03:56
rezaeimahdi's Avatar
mahdi
rezaeimahdi is on a distinguished road
For someone who has the same problem, I have written the solution procedure here:
Error in polyhedral-mesh (Fluent Meshing) conversion to OpenFOAM.
Regards,
rezaeimahdi is offline   Reply With Quote
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting arunraj FLUENT 0 June 2, 2016 22:58
[Other] Pointwise Mesh into Fluent - Error: "Divergence detected in AMG solver: ads-0." kyles.sverige ANSYS Meshing & Geometry 3 January 27, 2015 12:28
[Commercial meshers] converting fluent mesh to OpenFOAM sivakumar OpenFOAM Meshing & Mesh Conversion 2 April 12, 2012 06:20
[ICEM] Any successful way of converting Fluent Mesh (academic) to a CAD model? RossFS ANSYS Meshing & Geometry 2 February 20, 2011 18:59
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
