[snappyHexMesh] non-orthogonality problem
Old   November 8, 2021, 08:49
Default non-orthogonality problem
Tommaso Negosanti
tommynego95 is on a distinguished road
Hello all,
In the current study i'm following i need to mesh a complex body.
I decided to use snappyHexMesh since it has a good mesh capability and meshes with hexaedral elements.
The sHM process end with no problems exept the fact that i get a lot of non-orthogonals elements on my mesh, about 5000.
I don't get what i' m doing wrong
Here is the blockMeshDict file for the background mesh:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  9
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.001;
//x [-250;100]
//y [0;170]
//z [0;11.273]
vertices
    (-300 0 0)
    (500 0 0)
    (500 300 0)
    (-300 300 0)
    (-300 0 11)
    (500 0 11)
    (500 300 11)
    (-300 300 11)
blocks
    hex (0 1 2 3 4 5 6 7) (80 30 11) simpleGrading (1 1 1)
edges
boundary
    inlet
        type patch;
        faces
            (0 3 7 4)
    outlet
        type patch;
        faces
            (1 2 6 5)
            (7 6 2 3)
    front_back
        type empty;
        faces
            (0 3 2 1)
            (5 6 7 4)
    symmetry
    	type symmetryPlane;
    	faces
    	     (0 1 5 4)
The surfaceFeaturesDict
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       dictionary;
    object      surfaceFeaturesDict;
wall
	surfaces ("wall.stl");
	includedAngle 90;
	geometricTestOnly       yes;
	writeObj	yes;
porous_domain
	surfaces ("porous_domain.stl");
	includedAngle 90;
	writeObj	yes;
and the snappyHexMeshDict
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
castellatedMesh true;
snap            true;
addLayers       true;
geometry
    wall
        type closedTriSurfaceMesh;
        file "wall.stl";
    porous_domain
        file "porous_domain.stl";
    refinementBox
        type searchableBox;
        min (-0.3 0 0);
        max (0.25 0.2 0.011);
// Settings for the castellatedMesh generation.
castellatedMeshControls
    // Refinement parameters
    maxLocalCells 100000000;
    maxGlobalCells 200000000;
    minRefinementCells 10;
    maxLoadUnbalance 0.10;
    nCellsBetweenLevels 2;
    // Explicit feature edge refinement
    features
            file "wall.eMesh";
            levels ((2 3));
            file "porous_domain.eMesh";
            levels ((2 2));
    // Surface based refinement
    refinementSurfaces
        wall
            level (0 0);
            patchInfo
                type wall;
        porous_domain
            level (2 2);
            faceZone porous_domain;
            cellZone porous_domain;
            cellZoneInside inside;
            boundary internal;
            patchInfo
                type patch;
    resolveFeatureAngle 30;
    // Region-wise refinement
    refinementRegions
     refinementBox
            mode    inside;
            level   1;
    // Mesh selection
    locationInMesh (-0.25 0.001 0.005);
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    nSmoothPatch 5;
    tolerance 4.0;
    nSolveIter 100;
    nRelaxIter 5;
    // Feature snapping
        nFeatureSnapIter 30;
        implicitFeatureSnap false;
        explicitFeatureSnap true;
        multiRegionFeatureSnap false;
// Settings for the layer addition.
addLayersControls
    relativeSizes false;
    layers
        wall
        	nSurfaceLayers 5;
    expansionRatio 1.2;
    finalLayerThickness 0.2;
    minThickness 0.1;
    nGrow 0;
    featureAngle 30;
    slipFeatureAngle 30;
    nRelaxIter 3;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedianAxisAngle 90;
    nBufferCellsNoExtrude 0;
    nLayerIter 50;
meshQualityControls
    #include "meshQualityDict"
debug 1;
writeFlags
    scalarLevels
    layerSets
    layerFields
mergeTolerance 1e-6;
I also attach the .stl files so if anybody wants to help.
The .stl files are exported from a geometry i modeled in salome.
tommynego95 is offline   Reply With Quote
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
BuoyantBoussinesqSimpleFoam_Facing problem Mondal131211 OpenFOAM Running, Solving & CFD 1 April 10, 2019 19:41
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
