December 15, 2021, 04:59 |
Mesh Regions
Teh Tiong Wei
Rep Power: 4 |
Hi there!
I am trying to mesh two different regions (yarn and air) from a disconnected STL-groups for the yarn. I managed to mesh the regions, however the names of the region are not as what I have defined. It gives me: domain1, domain3, insideZone3 and outsideZone; where I would like it to be: insideZone1, insideZone2, insideZone3 and outsideZone. I guess this is due to how i wrote my snappyHexMeshDict, but I could not figure out how can I make this right. Any suggestions? Thanks in advance Cheers! |
December 15, 2021, 05:49 |
Yann
Rep Power: 26 |
I'm not totally sure, but I think you should try with 3 separate STL files for your 3 inside zones. I don't think you can use 3 times the same surface (inside) in refinementSurfaces. This would explain why the only inside zone correctly defined in your final mesh is the last one in your snappyHexMeshDict (insideZone3) Hope this helps, Yann |
cellzones, snappyhexmesh 3d |
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets | Struggle_Achieve | OpenFOAM Meshing & Mesh Conversion | 3 | June 17, 2019 09:29 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
