[mesh manipulation] Possible to do two region (porous and regular) complex meshing?
Old   February 12, 2022, 13:50
Default Possible to do two region (porous and regular) complex meshing?
Sourav Mandal
sourav90 is on a distinguished road
Dear all,
I wish to do porous media modeling of a complex interpenetrating region (one is for regular fluid flow, the other region is to be modeled as porous media with Darcy's law).
I have, at the moment, the 3D CT images that can be used for making meshes (the surface between those two phases can be exported as .stl or .obj mesh).
I am not sure which is the correct way to proceed. I see a lot of training and resources devoted to porous media modelling, but I came through none which handles a complex mesh like this (PFA the screenshots from blender & quickLook). Once I solve this problem, the simulation part is pretty regular. I even wonder will it be possible to do using OpenFOAM? Thanks in advance, for your suggestions /hints!
sourav90 is offline   Reply With Quote
meshing, multi domain, multiregion meshing, multiregions
Velocity jump near porous media Pyrokrates OpenFOAM Programming & Development 0 January 25, 2022 06:15
FLUENT porous zone inputs eishinsnsayshin FLUENT 19 April 17, 2020 04:40
Interface between Fluid and Homogeneous Porous Media guilbemloco FLUENT 0 June 11, 2015 09:18
