February 17, 2022, 04:12 |
Cgns to Foam
Boucetta Lahcene
Rep Power: 4 |
I have a mesh in cgns format and I want to transform it in OpenFoam. (openFOAM V6 version) Do I have to install a converter or is there a simple way to do it? Thank you dear comunity |
February 17, 2022, 08:32 |
Niels Nielsen
Rep Power: 27 |
The CGNS converters can be a bit of a headache to get working. Also not up to date with the newer versions of OF. https://openfoamwiki.net/index.php/S...GNS_Converters
Salome has the possibility to import CGNS files in the Mesh program. Maybe try importing into Salome and then export as UNV and use ideasUnvToFoam command. Tried with the last file in this list. https://cgns.github.io/CGNSFiles.html
Linnemann PS. I do not do personal support, so please post in the forums. |
February 17, 2022, 11:25 |
Boucetta Lahcene
Rep Power: 4 |
Hello linnemann,
Thank you for the answer. I'm new that's why I don't really know how it goes. but don't worry I've taken note ciao |
January 10, 2023, 15:26 |
cgnsToFoam for Windows
Rep Power: 3 |
Hello guys,
Any of you know if it is possible to install a pre-compiled version of cgnsToFoam in OpenFOAM for Windows (native version, mingw64)? I am trying to do something of the sort, but without success until now. Thank you in advance. |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 02:21 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
