[Commercial meshers] ccmToFoam Problem
Old   November 7, 2020, 11:17
Default ccmToFoam Problem
andrea chianese
Joffy is on a distinguished road
Hi everybody,
I'm having problems with ccmToFoam installation.
I have downloaded the Libccmio-2.6.1.folder (85MB), put it in the thirdparty folder and followed this instructions:
cd $WM_THIRD_PARTY_DIR
./makeCCMIO libso
./makeCCMIO lib
foam
./Allwmake
Afterwards, for the legacy converter (if you need it):
app
cd utilities/mesh/conversion/ccm
./Allwmake
but at last step I have still the same error;
==> skip optional ccm conversion components (no libccm.so)
PLS can somebody helps me? this work is for my thesis.
when I use the first command in Thirdparty folder:
cpMakeFiles libccmio .
wmake lib (libccmio-2.6.1)
Making dependency list for source file ccmioversion.c
Making dependency list for source file ccmioutility.c
Making dependency list for source file ccmiocore.c
Making dependency list for source file ccmioprivate.c
Making dependency list for source file ccmio.c
Making dependency list for source file ADF_internals.c
Making dependency list for source file ADF_interface.c
Making dependency list for source file ADF_fortran_2_c.c
gcc -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -IlnInclude -I. -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c libadf/ADF_fortran_2_c.c -o Make/linux64GccDPInt32Opt/libadf/ADF_fortran_2_c.o
gcc -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -IlnInclude -I. -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c libadf/ADF_interface.c -o Make/linux64GccDPInt32Opt/libadf/ADF_interface.o
gcc -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -IlnInclude -I. -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c libadf/ADF_internals.c -o Make/linux64GccDPInt32Opt/libadf/ADF_internals.o
gcc -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -IlnInclude -I. -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c libccmio/ccmio.c -o Make/linux64GccDPInt32Opt/libccmio/ccmio.o
libccmio/ccmio.c: In function ‘MakeEntityName’:
libccmio/ccmio.c:523:40: warning: format not a string literal and no format arguments [-Wformat-security]
snprintf(name, kCCMIOMaxStringLength, gEntityNames[(int)type]);
libadf/ADF_internals.c: In function ‘DC_flush_range’:
libadf/ADF_internals.c:696:29: warning: variable ‘prev’ set but not used [-Wunused-but-set-variable]
struct DISK_CACHE_NODE *prev, *node = disk_cache;
gcc -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -IlnInclude -I. -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c libccmio/ccmiocore.c -o Make/linux64GccDPInt32Opt/libccmio/ccmiocore.o
gcc -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -IlnInclude -I. -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c libccmio/ccmioprivate.c -o Make/linux64GccDPInt32Opt/libccmio/ccmioprivate.o
gcc -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -IlnInclude -I. -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c libccmio/ccmioutility.c -o Make/linux64GccDPInt32Opt/libccmio/ccmioutility.o
libccmio/ccmioutility.c: In function ‘CCMIOCopyNode’:
libccmio/ccmioutility.c:302:6: warning: attempt to free a non-heap object ‘dims’ [-Wfree-nonheap-object]
free(dims);
gcc -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -O3 -IlnInclude -I. -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/openfoam/v1706/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c libccmio/ccmioversion.c -o Make/linux64GccDPInt32Opt/libccmio/ccmioversion.o
ar cr /opt/openfoam/v1706/OpenFOAM-v1706/platforms/linux64GccDPInt32Opt/lib/libccmio.a Make/linux64GccDPInt32Opt/libadf/ADF_fortran_2_c.o Make/linux64GccDPInt32Opt/libadf/ADF_interface.o Make/linux64GccDPInt32Opt/libadf/ADF_internals.o Make/linux64GccDPInt32Opt/libccmio/ccmio.o Make/linux64GccDPInt32Opt/libccmio/ccmiocore.o Make/linux64GccDPInt32Opt/libccmio/ccmioprivate.o Make/linux64GccDPInt32Opt/libccmio/ccmioutility.o Make/linux64GccDPInt32Opt/libccmio/ccmioversion.o
ranlib /opt/openfoam/v1706/OpenFOAM-v1706/platforms/linux64GccDPInt32Opt/lib/libccmio.a
'libccmio/ccmio.h' -> '/opt/openfoam/v1706/ThirdParty-v1706/platforms/linux64Gcc/libccmio-2.6.1/include/libccmio/ccmio.h'
'libccmio/ccmiocore.h' -> '/opt/openfoam/v1706/ThirdParty-v1706/platforms/linux64Gcc/libccmio-2.6.1/include/libccmio/ccmiocore.h'
'libccmio/ccmioprivate.h' -> '/opt/openfoam/v1706/ThirdParty-v1706/platforms/linux64Gcc/libccmio-2.6.1/include/libccmio/ccmioprivate.h'
'libccmio/ccmiotypes.h' -> '/opt/openfoam/v1706/ThirdParty-v1706/platforms/linux64Gcc/libccmio-2.6.1/include/libccmio/ccmiotypes.h'
'libccmio/ccmioutility.h' -> '/opt/openfoam/v1706/ThirdParty-v1706/platforms/linux64Gcc/libccmio-2.6.1/include/libccmio/ccmioutility.h'
'libccmio/ccmioverifymesh.h' -> '/opt/openfoam/v1706/ThirdParty-v1706/platforms/linux64Gcc/libccmio-2.6.1/include/libccmio/ccmioverifymesh.h'
'libccmio/ccmioversion.h' -> '/opt/openfoam/v1706/ThirdParty-v1706/platforms/linux64Gcc/libccmio-2.6.1/include/libccmio/ccmioversion.h'
root@andrea-desktop:/opt/openfoam/v1706/ThirdParty-v1706# ./makeCCMIO lib
after the second command in OpenFoam-V1806:
wmake libso (conversion)
==> skip optional libccm adapter
Joffy is offline   Reply With Quote
Old   May 13, 2022, 07:46
AlxB is on a distinguished road
Hello Joffy,
did you solve the issue ?
if so, please may I know how ?
I am using OF2112 and doing
./Allwmake
in the src/conversion/ccm folder leads to :
==> skip ccmio (no header)
AlxB is offline   Reply With Quote
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
