[Other] AMR : How to apply AMR only inside one region ??
Old   January 16, 2023, 06:43
Question AMR : How to apply AMR only inside one region ??
H.Ham
kimou is on a distinguished road
Greetings fellow Foamers,
I am currently working on a two-phase flow configuration involving a waterfall gravity driven system. I am utilizing Adaptive Mesh Refinement (AMR) to focus the refinement around the water jet. I am refining for alpha.water between 0.005 and 0.99 in order to capture the entirety of the water jet.
However, as shown in the attached image (bottom right corner), there are some liquid structures emerging outside of the jet. As a result, I am experiencing an excessive amount of cells.
Is there any tricks or techniques to impose AMR only within the designated red square in the figure ? Any suggestions would be greatly appreciated.
You will find attached the dynamicMeshDict script and the figure of the mesh in question?
--------------------------dynamicFvMesh---------------------------------
dynamicFvMesh dynamicRefineFvMesh;
// How often to refine
refineInterval 1;
// Field to be refinement on
field alpha.water;
// Refine field inbetween lower..upper
lowerRefineLevel 0.0005;
upperRefineLevel 0.999;
// If value < unrefineLevel unrefine
unrefineLevel 10;
// Have slower than 2:1 refinement
nBufferLayers 1;
// Refine cells only up to maxRefinement levels
maxRefinement 2;
// Stop refinement if maxCells reached
maxCells 100000000;
kimou is offline   Reply With Quote
How to apply motion to overset region Henry Arrigo STAR-CCM+ 14 June 28, 2021 06:38
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
Apply Rotation Speed of Rotating Region Joke Main CFD Forum 0 September 19, 2011 09:48
Apply a BC from library directly inside the solver ? T.D. OpenFOAM 0 April 5, 2011 04:39
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
