[Other] Ansys Fluent to OpenFOAM
Like Tree2Likes
  • 1 Post By DJARA
  • 1 Post By mr35diamonds
Old   June 24, 2022, 18:23
Default Ansys Fluent to OpenFOAM
Silver Blaze
silver.blaze is on a distinguished road
Dear Altruist,
I am a new user of OpenFOAM.com. I have installed OpenFOAM in windows subsystem for Linux. I am working on a CFD simulation of flows around 2D airfoil. I am using k-epsilon turbulent model. First I have done this in Ansys 2021 R2 Version. I am want to do this in OpenFoam. I have heard that OpenFOAM can read ansys mesh. Now I want to know, how can I do this? What kind of file I have to create? Should I create constant, controldict folder? Actually I have watched some video which tells me I have to save the ansys mesh in ASCII format. But what should I do then?
Kindly help me with this.
Thanks in advance.
silver.blaze is offline   Reply With Quote
Old   July 1, 2022, 08:53
Daniel Jara Heredia
DJARA is on a distinguished road
Where you able to solve the problem?
I would like to go from .msh file to .vtk. I am unsure about to use mshToFoam, FluentToFoam or Fluent3DMeshToFoam.
I have run the command but it failed, apparently I need some files such as the ControlFict, fvSchemes, fvSolution in the subfolder system and probably I also need something in the constant subfolder.
I am also new to OpenFoam and basically I am pretty lost and as usual cannot rely on other help that the altruism of Forum people.
Thanks
silver.blaze likes this.
DJARA is offline   Reply With Quote
Old   July 27, 2022, 08:32
Justin
mr35diamonds is on a distinguished road
Your .msh file from fluent will have to be ASCII format, then if it's imported from windows, do:
dos2unix <insert .msh file name here>
FluentMeshToFoam <insert .msh file name here>
this should create a paramesh directory so you do not need to use the blockMesh utility. Suggest to copy a tutorial file in $FOAM_TUTORIALS to set up a new case.
mr35diamonds is offline   Reply With Quote
ansys, kepsilon, openfoam, simplefoam
GPU acceleration in Ansys Fluent flotus1 Hardware 63 May 12, 2023 02:48
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
gambit in Ansys FLuent 13 saharesobh FLUENT 0 August 1, 2012 15:30
