[snappyHexMesh] Internal Snapping using SnappyHexMesh |
July 20, 2022, 10:44 |
Laurens
Rep Power: 5 |
I am facing some issues with SnappyHexMesh, when I turn on snapping, these weird lines show up in the centre of the mesh. I have looked online but can't find that much. Below you can find the snapControls I used: snapControls { nSmoothPatch 3; tolerance 1.5; nSolveIter 100; nRelaxIter 5; nFeatureSnapIter 10; implicitFeatureSnap false; explicitFeatureSnap true; multiRegionFeatureSnap false; } Any help is more than welcome, thank you. Laurens |
July 20, 2022, 10:47 |
Yann
Rep Power: 26 |
Hi Laurens,
This is a common question, have a look at the links pointed out there: Dynamic mesh using snappyHM Cheers, Yann |
meshing 3d, meshing and geometry, snappyhexmesh 3d |
[snappyHexMesh] snappyHexMesh does not detect highly skewed faces? | ptpacheco | OpenFOAM Meshing & Mesh Conversion | 1 | January 4, 2022 12:37 |
[snappyHexMesh] snappyHexMesh does not remove internal cells | Binglian Hu | OpenFOAM Meshing & Mesh Conversion | 16 | June 3, 2021 09:38 |
[snappyHexMesh] How to generete internal domain from snappyHexMesh? | sunagra27 | OpenFOAM Meshing & Mesh Conversion | 0 | March 4, 2021 23:44 |
[snappyHexMesh] SnappyHexMesh Internal Mesh problem | tenichols19 | OpenFOAM Meshing & Mesh Conversion | 2 | October 2, 2019 07:39 |
[snappyHexMesh] SnappyHexMesh Internal Flow Example (Diesel Injector) | Irish09 | OpenFOAM Meshing & Mesh Conversion | 23 | July 15, 2013 07:45 |
