[mesh manipulation] Evaluating Cell Quality
Old   May 14, 2005, 23:31
Default Evaluating Cell Quality
vas
Vassili Kitsios
vas is on a distinguished road
I am undertaking a PhD at Monash University in Australia developing a novel shape optimisation method. I am looking to develop a stricter halt criteria involving various measures of model quality, including cell field gradients and cell quality.
I have modified the analyticalCylinder tutorial example to calculate the following:
  • analytical solution for complete 360 deg;
  • difference between the analtical and numerical solution;
  • cell field gradients;
  • cell quality; and
  • finally write all of the information to file.
I am having trouble, however, in getting the cellQuality class to compile. I keep getting the following error: "undefined reference to 'Foam::cellQuality::cellQuality(Foam::polyMesh const&)'
I have attached the code and has been extensively commented. I was wondering if someone could please identify my error.
analyticalCylinder.C
createGradFields.H
createCellQualityFields.H
vas is offline   Reply With Quote
Old   May 15, 2005, 02:22
Default You probably need to link the
Hrvoje Jasak
You probably need to link the dynamic mesh library - that's where the cellQuality class has been defined.
Edit the Make/options and under EXE_LIBS add -ldynamicMesh
There may be some other libraries missing when you do that (maybe meshTools or cfdTools); the procedure is the same.
Enjoy,
Hrv
Hrvoje Jasak
Old   May 15, 2005, 06:25
Default Thank you Hrvoje, You were
vas
Vassili Kitsios
Thank you Hrvoje,
You were right, I hadn't included the libraries properly. Now that this component is working, I can send the data to Info, but I am not sure how to write the data to file.
In "createGradFields.H" I initialised the volScalarField and volVectorField types using IOobject and was able to write the data to file. I attempted to do the same thing in "createCellQualityFields.H", but the compiler returned the following error message:
no matching function for call to 'Foam::tmp<foam::field<foam::scalar> >::tmp(Foam::IOobject)'
Some possible alternative functions are then proposed from "tmpI.H".
I have reattached the files with some minor modifications from the previous message. I would greatly appreciate it if you could help me again with this query.
Old   May 15, 2005, 06:27
vas
Vassili Kitsios
Thank you Hrvoje,
createGradFields.H
Old   May 15, 2005, 06:57
Default Two errors: 1) You are tryi
Hrvoje Jasak
Two errors:
1) You are trying to create tmp<scalarfield> in createCellQualityFields.H, which does not make sense: tmp is a wrapper that allows you to "copy" field (and other) objects without actually copying the data. What you want to create are scalar fields that can write themselves out, right. If so, you need to use scalarIOField. Funnily enough, the rest of the statement is OK! :-)
scalarIOField cellSkewness
IOobject
"cellSkewness",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
2) main code, line 99. You said cellQuality.write(), but cellQuality is a class. This is probably a typo, I bet you wanted:
cellNonOrthogonality.write();
I loke the code organisation and use of field algebra - well done. You should also try to indent the code according to the rules and it will be very nice indeed!
Enjoy,
Hrv
Hrvoje Jasak
Old   May 16, 2005, 00:23
Default Cheers Hrvoje, That worked
vas
Vassili Kitsios
Cheers Hrvoje,
That worked and I could write the information to file. I have a couple more questions though if it is ok.
I am using paraView to view the data and hense, I am running the foamToVTK utility. This utility, however, does not convert the cellSkewness and cellQuality files.
I modified the output files to be identical to the formats generated from the volScalarField type. This worked and foamToVTK then converted these files as well.
I then tried replacing the scalarIOField type name for volScalarField but received the following error and provides some possible function candidates.
no match for 'operator=' in 'cellskewness = Foam::cellQuality::skewness() const()'
I was wondering if there is a way to initialise the cellSkewness and cellNonOrthogonality variables as volScalarFields to ensure the data is written in a format that the foamToVTK utility can convert. Unless there is a meas to convert the scalarIOField output to VTK format somehow.
Also I have a separate question, still related to mesh quality. Is there a utility to calculate the geometric volume of a cell, as I want to be able to capture cell volume gradients?
Cheers Vassili
Old   May 16, 2005, 05:24
Default I would suggest making volScal
Hrvoje Jasak
I would suggest making volScalarFields to start with. You can do the op = as follows:
cellSkewness.internalField() = qualityCheck.skewness();
Ditto for cell volumes.
A word of warning: if you want grad of cell volumes, you need to say something about boundary conditions, i.e. whether you want the volume on the boundary to be zero or zero gradient. By default, the constructor for volScalarField (and other geometric fields) will take a "calculated" b.c., so if you do (sorry, different names):
volScalarField vols
IOobject
"vols",
runTime.timeName(),
mesh,
IOobject::NO_READ,
mesh,
dimensionedScalar("zero", dimVolume, 0.0)
you get zeros on the boundary, which affects the gradient (and probably in the right way! but you'll know whether that's what you want). :-)
Here's an example with zeroGradient boundaries:
volScalarField A
IOobject
"A",
runTime.timeName(),
mesh
mesh,
dimensionedScalar("A", dimless/dimTime, 1),
zeroGradientFvPatchScalarField::typeName
You will need an include file for zeroGradient:
#include "zeroGradientFvPatchFields.H"
Aha, volumes:
vols.internalField() = mesh.V();
(and then if you want):
vols.correctBoundaryConditions();
Isn't FOAM nice!
Enjoy,
Hrv
Hrvoje Jasak
Old   May 16, 2005, 21:50
Default Thanks Hrvoje, I have made
vas
Vassili Kitsios
Thanks Hrvoje,
I have made those modifications and uploaded the final files for anyone else that might want to utilise the code.
One note, however, in my mesh the nonOrthogonality function returned "nan" instead of a numerical result for a handful of cells in my mesh. Not sure why as these cells were not excessively nonOrthogonal or orthogonal for that matter.
createAnalyticalFields.H
createGradFields.H
files
options
Cheers Vas
Old   May 17, 2005, 05:07
Default Hi Vassili, The nan is usua
Mattijs Janssens
mattijs is on a distinguished road
Hi Vassili,
The nan is usually caused by a division by zero somewhere. If you rerun with environment variables
FOAM_SIGFPE
FOAM_ABORT
all set (to a non-empty value) the code should fall over immediately and you can use a debugger to look at where it goes wrong.
mattijs is offline   Reply With Quote
Old   May 18, 2005, 05:45
Default Thanks Hrvoje, I'll give th
vas
Vassili Kitsios
Thanks Hrvoje,
I'll give that a go.
I have also been reading through the discussion board and there are various mentions of your thesis and the error estimation tools. I have been playing around with these FOAM functions and I would appreciate some further reading on the rational behind these functions.
I was wondering if you have a soft copy of your thesis that you could forward me. It would be much appreciated. My email address is vassili_kitsios@yahoo.com
Cheers Vas
Old   May 18, 2005, 05:58
Default Sorry Hrvoje, I found the l
  #11
vas
Vassili Kitsios
Sorry Hrvoje,
I found the location your paper on the web from another area in the discussion group. I will go through it and possibly get back to you later.
Cheers Vas
Old   May 18, 2005, 09:30
Default Hello Vassili, No problem -
  #12
Hrvoje Jasak
Hello Vassili,
No problem - actually, a list of all my papers, including my PhD work on error estimation and adaptive meshing + FV discretisation etc. are available on my private web page:
http://www.h.jasak.dial.pipex.com/
All the research + code development has been done in FOAM over the last 12 years. If you want any of the papers that you cannot find on the web, please let me know.
I usually put my presentation slides there as well - you may find some interesting info on FOAM structure etc. This may not be the best place for it, but what started as a private home page now looks like FOAM-related data repository. :-) I will probably have to move it to a more sensible web address but that will be announced here.
As for talking about the work - I'd be delighted. Please feel free to contact me by E-mail.
Have fun,
Hrv
Hrvoje Jasak
Old   January 9, 2008, 05:15
Default Hi, I tried to use the code a
  #13
David Segersson
segersson is on a distinguished road
I tried to use the code attached above and found that it is out of date (think it's from OF 1.2).
Is there a recommended way to locate cells with low quality in OF? checkMesh writes a faceSet with nonOrthoFaces and I was thinking about writing a scalar field marking the cells containing these faces. It seems like this must have been done by a lot of users before. Is there anybody who can give me the steps to take or maybe send a code snippet?
Regards
David
segersson is offline   Reply With Quote
Old   January 9, 2008, 05:41
Default Much easier that that: use set
  #14
Hrvoje Jasak
Much easier that that: use setSet. A Help will give you an idea on how to use it - here's a little snippet I use often when dealing with poor meshes:
cellSet cellSet0 new faceToCell wrongOrientedFaces any
Got the gist?
Hrv
Hrvoje Jasak
Old   January 9, 2008, 06:13
Default Thanks Hrvoje, I'm trying to
  #15
David Segersson
Thanks Hrvoje,
I'm trying to compile setSet by running the Allwmake script and have trouble with:
.../libreadline.a: No such file or directory
Any hint on this as well?
David
Old   January 9, 2008, 06:33
Default Some care required - follow th
  #16
Hrvoje Jasak
Some care required - follow the Allwmake script by hand (with understanding - the "parrot mode" will not work). You need to compile readline, adjust paths and variables to get it right and read messages about missed paths and libraries.
I have tried to get this sorted out but it seems the libraries never end up in consistent places between various linux flavours. Works on my machine though...
Hrv
Hrvoje Jasak
Old   June 23, 2008, 10:54
Default The problem lies in the fact t
  #17
Eugene de Villiers
eugene is on a distinguished road
The problem lies in the fact that skewness is a face based property. The cellQuality.skewness() call returns a field of size nCells where the "cell" value is the max of all faces bordering a particular cell. If you want to change this behavior, call the faceSkewness function and create the cell-skewness field the way you want to.
I guess the cell-based return type is nice for post-processing, but it is also misleading if you are not aware of the implementation.
eugene is offline   Reply With Quote
Old   July 29, 2008, 09:38
Default Hi, Does anyone know the d
  #18
Frank Bos
lr103476 is on a distinguished road
Does anyone know the difference between cellQuality.skewnewss() and mesh.checkFaceSkewness().
I mean, I get different maximal values while monitoring.....
Frank
Frank Bos
lr103476 is offline   Reply With Quote
Old   August 1, 2008, 13:49
Default Anyone? What's the differen
  #19
Frank Bos
Anyone?
What's the difference between cellQuality.skewnewss() and mesh.checkFaceSkewness().
Thanks, Frank
Frank Bos
Old   August 1, 2008, 16:17
Default The one from checkFaceSkewness
  #20
Mattijs Janssens
The one from checkFaceSkewness tries to include a measure of the 'height' of the face in the direction of the face centre. Gives more reasonably values for high aspect ratio faces.
[snappyHexMesh] very bad quality snapped mesh federicabi OpenFOAM Meshing & Mesh Conversion 18 September 26, 2018 10:33
Fluent UDF wrong number of cells in parallel - correct in serial dralexpe Fluent UDF and Scheme Programming 7 May 17, 2018 08:26
Particle tracking error alchem OpenFOAM Bugs 5 May 6, 2017 16:30
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
cell to cell relation CMB Siemens 1 December 4, 2003 04:05
