[mesh manipulation] How to export an OpenFoam mesh |
October 3, 2022, 11:35 |
Rep Power: 5 |
Hey everyone!
I am looking for a way to export a mesh written in the polymesh folder of an OpenFoam case, so that I can save it to a .cgns, .unv or .med file, and eventually use it in code_saturne. I tried several things:
I also looked into softwares that would allow the user to read an openfoam case and then save the mesh separately (I know cfMesh+ can do that, I also tried with Helyx OS and simflow without any success). There is also a community utility foamToMed written for OF2.0 if I remember correctly, but I have to work with OFv2206... And now I am running out of ideas does anyone have any experience with this kind of issue? Thanks for the help! |
October 4, 2022, 09:48 |
Rep Power: 5 |
Hey!
I eventually found a workaround which does not need to use OF meshers: I used the Reverse Engineering module of FreeCad to map a bspline surface to my elevation map. Then I could use all the boolean operations needed in Salome. If anyone does have an actual solution for the original question, feel free to post it |
[OpenFOAM.com] Problem installation OpenFOAM 6 | wamars | OpenFOAM Installation | 0 | June 23, 2020 09:01 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Mesh export to OpenFOAM issue | sihaqqi | OpenFOAM Pre-Processing | 2 | March 2, 2013 22:14 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
