[snappyHexMesh] Bulges in mesh when using snappyHexMesh
Like Tree1Likes
  • 1 Post By Yann
Old   November 10, 2022, 03:10
Default Bulges in mesh when using snappyHexMesh
bruno Vanderschelden
bvdrsch is on a distinguished road
Hello Foamers,
I'm trying to perform a wind study on buildings. Therefore a build my 3D model in sketchup and converted it via blender to an .stl file. See attachement.
I'm using snappyHexMesh for the mesh. However when I use the addlayers possibility, some bulges arise on the edge of the surfaces.
I noticed some mid surface bulges as well.
Can somebody explain how this can occur or what a solution could be?
kr
Bruno
| \\ / O peration | Version: v1806 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
#includeEtc "caseDicts/mesh/generation/snappyHexMeshDict.cfg"
castellatedMesh on;
snap on;
addLayers yes;
geometry
cube.stl
type triSurfaceMesh;
name cube;
castellatedMeshControls
features
{ file "cube.eMesh"; level 0; }
refinementSurfaces
cube
level (2 5);
patchInfo { type wall; }
refinementRegions
refinementBox
mode inside;
levels ((1E15 2));
locationInMesh (1 1 1);
snapControls
explicitFeatureSnap true;
implicitFeatureSnap false;
addLayersControls
layers
cube
nSurfaceLayers 3;
relativeSizes true;
expansionRatio 1.3;
finalLayerThickness 0.5;
minThickness 1e-3;
meshQualityControls
writeFlags
noRefinement
// scalarLevels
// layerSets
// layerFields
mergeTolerance 1e-6;
FoamFile
version 2.0;
format ascii;
class dictionary;
object surfaceFeatureExtractDict;
cube.stl
#includeEtc "caseDicts/surface/surfaceFeatureExtractDict.cfg"
bvdrsch is offline   Reply With Quote
Old   November 14, 2022, 03:41
Yann
Yann will become famous soon enough
It would help if you could post a screenshot showing the issue you are talking about.
Regards,
Yann
Yann is offline   Reply With Quote
Old   November 14, 2022, 04:45
Default Issues
Thank you for your help.
These bulges on the edge are the ones I was talking about:
kr
Bruno
Old   November 14, 2022, 05:40
Yann
Thanks.
Try to add this parameter do you addLayersControls:
addLayersControls
	layers
		cube
			nSurfaceLayers 3;
	relativeSizes true;
	expansionRatio 1.3;
	minThickness 1e-3;
	mergePatchFacesAngle 45;
Does it change something?
How is your layer coverage on your geometry, especially on these areas?
Regards,
Yann
cibanez likes this.
bulges, meshes, qualitymesh, snappyhexmesh
[snappyHexMesh] Creating very fine, high accuracy mesh with snappyHexMesh JD_Welch OpenFOAM Meshing & Mesh Conversion 10 July 5, 2023 11:50
[snappyHexMesh] snappyHexMesh does not detect highly skewed faces? ptpacheco OpenFOAM Meshing & Mesh Conversion 1 January 4, 2022 12:37
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[snappyHexMesh] snappyHexMesh & Mesh around a missile sasanghomi OpenFOAM Meshing & Mesh Conversion 2 October 15, 2014 19:54
[snappyHexMesh] SnappyHexMesh not generate mesh first time mavimo OpenFOAM Meshing & Mesh Conversion 4 August 26, 2008 07:08
