[snappyHexMesh] Bulges in mesh when using snappyHexMesh |
November 10, 2022, 03:10 |
#1 | ||
bruno Vanderschelden
Hello Foamers,
I'm trying to perform a wind study on buildings. Therefore a build my 3D model in sketchup and converted it via blender to an .stl file. See attachement. I'm using snappyHexMesh for the mesh. However when I use the addlayers possibility, some bulges arise on the edge of the surfaces. I noticed some mid surface bulges as well. Can somebody explain how this can occur or what a solution could be? kr Bruno Quote:
November 14, 2022, 03:41 |
Yann
Rep Power: 26 |
It would help if you could post a screenshot showing the issue you are talking about. Regards, Yann |
November 14, 2022, 04:45 |
Issues
Thank you for your help. These bulges on the edge are the ones I was talking about: kr Bruno |
November 14, 2022, 05:40 |
Yann
Rep Power: 26 |
Thanks.
Try to add this parameter do you addLayersControls: Code:
addLayersControls { layers { cube { nSurfaceLayers 3; } } relativeSizes true; expansionRatio 1.3; finalLayerThickness 0.5; minThickness 1e-3; mergePatchFacesAngle 45; } How is your layer coverage on your geometry, especially on these areas? Regards, Yann |
bulges, meshes, qualitymesh, snappyhexmesh |
[snappyHexMesh] Creating very fine, high accuracy mesh with snappyHexMesh | JD_Welch | OpenFOAM Meshing & Mesh Conversion | 10 | July 5, 2023 11:50 |
[snappyHexMesh] snappyHexMesh does not detect highly skewed faces? | ptpacheco | OpenFOAM Meshing & Mesh Conversion | 1 | January 4, 2022 12:37 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] snappyHexMesh & Mesh around a missile | sasanghomi | OpenFOAM Meshing & Mesh Conversion | 2 | October 15, 2014 19:54 |
[snappyHexMesh] SnappyHexMesh not generate mesh first time | mavimo | OpenFOAM Meshing & Mesh Conversion | 4 | August 26, 2008 07:08 |
