[snappyHexMesh] Strange thin layer at interface between two regions |
January 31, 2023, 09:19 |
Rep Power: 3 |
I want to perform a conjugate heat-flow simulation and thus needs to mesh multi regions, including fluid and solids. A simplified case is attached which includes a chamber and a plate, as well as all needed files to run. Strange cells are generated by snappyHexMesh at the interface between the chamber and the plate. These strange cells belong to the chamber and is a thin layer. In addition they seems not connected to the lower cells of chamber. Meanwhile besides the /chamber/patch/chamber_to_plate, there is an extra patch with the name of "plate" under /chamber/patch/ in paraView. ParaView shows this patch is composed of double layers of surface but in original stl surface "plate" it is a single layer surface. In the attached figures, all cliping is done at (0,0,0) with normal of (0,1,0). The version of openFoam I used is v2206. Any idea is appreciated! Thank you in advance! |
January 31, 2023, 09:23 |
Rep Power: 3 |
The rest figures to be uploaded.
February 1, 2023, 04:46 |
Rep Power: 3 |
Further investigation shows after the 1st step of snappyHexMesh, the original stl surface of plate becomes a flat patch, i.e. two layers of cells overlap with each other. This patch "plate" locates at the lower surface of original stl surface of plate. The two overlapped layers behaves as a boundary in cells of chamber, i.e. the cells of chamber adjacent the two layers in patch of plate do not connect to each other, and leads to the split in 2nd step of snappyHexMesh.
Can anybody give advice? I guess the problem relates to the fact the region "plate" is completely in the region "chamber" which causes some issue when assigning cells to region. |
February 10, 2023, 00:30 |
Rep Power: 3 |
Trials found after changing the number of cell along x, y, and z in background mesh the problem vanishes, e.g.
original: (with issue at interface) Code:
xCells 172; yCells 172; zCells 115; new: (without the mentioned problem) Code:
xCells 180; yCells 180; zCells 120; Does anybody know the reason? Or is it a bug in snappyHexMesh? |
[snappyHexMesh] Layer coverage at 98% with collapses at corners | oryx | OpenFOAM Meshing & Mesh Conversion | 1 | December 4, 2023 19:04 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Prismatic boundary layer | KateEisenhower | enGrid | 5 | September 15, 2015 07:48 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
