[snappyHexMesh] Multiregion Snappy Hex Mesh
Old   February 8, 2023, 11:58
Default Multiregion Snappy Hex Mesh
Rachele Zamboni
rachele is on a distinguished road
Hello everyone, I am working on a multi-region mesh with SHM to define different components of an electric motor. Some of the stl are correctly turned into cellZone as required in the code, other instead do not produce cellZone but only faceZone. All stl used are closed surfaces controlled with surfaceCheck. I can't share the stl but following I report the snappy hex mesh dict.
Is there any constrains that I should respect in the cellZone definition like order of definition? I have tried also whit the definition of the inside point, solution that works for surface_in cell zone but for example not for shaft_cooling_duct for example.
I dont understand why just some of them is correctly defined. If some has any suggestion it will be appreciated. Thanks.
geometry
surface_out
type triSurfaceMesh;
file "surface_out.stl";
surface_in
file "surface_in.stl";
cooling_channels
file "cooling_channels.stl";
cooling_shaft
file "cooling_shaft.stl";
shaft
file "shaft.stl";
shaft_cooling_duct
file "shaft_cooling_duct.stl";
shaft_cooling_flow
file "shaft_cooling_flow.stl";
rotor_component_1
file "rotor_component_1.stl";
rotor_component_2
file "rotor_component_2.stl";
rotor_windings
file "rotor_windings.stl";
hole_shaft
file "hole_shaft.stl";
external_duct
file "external_duct.stl";
castellatedMeshControls
maxLocalCells 1000000000;
maxGlobalCells 2000000000;
minRefinementCells 0;
maxLoadUnbalance 0.10;
nCellsBetweenLevels 4;
features
file "surface_out.eMesh";
level 3;
file "surface_in.eMesh";
level 3;
file "cooling_channels.eMesh";
level 4;
file "cooling_shaft.eMesh";
level 4;
file "shaft.eMesh";
level 4;
file "shaft_cooling_duct.eMesh";
level 5;
file "shaft_cooling_flow.eMesh";
level 5;
file "rotor_component_1.eMesh";
level 2;
file "rotor_component_2.eMesh";
level 2;
file "rotor_windings.eMesh";
level 4;
file "hole_shaft.eMesh";
level 2;
file "external_duct.eMesh";
level 2;
refinementSurfaces
surface_out // rimuovere celle esterne
level (3 3);
external_duct
level (2 2);
surface_external
level (2 2);
faceZone surface_out_surface;
cellZone surface_out;
mode inside;
external_duct_zone //definizione cellzone dello spessore del guscio motore
level (3 3);
faceZone external_duct_surface;
cellZone external_duct;
mode inside;
surface_in
level (3 3);
faceZone internal_surface;
cellZone internal;
cellZoneInside insidePoint;
insidePoint (10 57 -109);
cooling_channels
level (5 5);
faceZone cooling_channels_surface;
cellZone cooling_channels;
mode inside;
cooling_shaft
level (5 5);
faceZone cooling_shaft_surface;
cellZone cooling_shaft;
mode inside;
rotor_component_1 //cilindro
level (2 2);
faceZone rotor_component_1_surface;
cellZone rotor_component_1;
mode inside;
rotor_component_2 //cilindro dentro il quale ci sono gli avvolgimenti
level (2 2);
faceZone rotor_component_2_surface;
cellZone rotor_component_2;
mode inside;
shaft
level (3 3);
faceZone shaft_surface;
cellZone shaft;
mode inside;
shaft_cooling_duct
level (5 5);
faceZone shaft_cooling_duct_surface;
cellZone shaft_cooling_duct;
insidePoint (0.5 0 0);
shaft_cooling_flow
level (2 2);
faceZone shaft_cooling_flow_surface;
cellZone shaft_cooling_flow;
mode inside;
rotor_windings
level (4 4);
faceZone rotor_windings _surface;
cellZone rotor_windings ;
mode inside;
hole_shaft
level (2 2);
faceZone hole_shaft_surface;
cellZone hole_shaft;
mode inside;
refinementRegions
locationInMesh (5 37 43);
resolveFeatureAngle 5;
// Settings for the snapping.
snapControls
nSmoothPatch 3;
tolerance 4.0;
nSolveIter 300;
nRelaxIter 5;
nFeatureSnapIter 10;
implicitFeatureSnap false;
explicitFeatureSnap true;
multiRegionFeatureSnap true;
rachele is offline   Reply With Quote
Old   February 21, 2023, 04:09
Nico
Hr_kules is on a distinguished road
there probably is a right answer to that, but i wasted 3/4 of year trying to understand multiregion meshing in snappyHexMesh. If you are willing to try, i would investigate the heated duct tutorial for chtMultiregionFoam. However, if your application must be done with more cellZones i would probably switch to gmsh. It is quite easy to learn and i haven't done a multi region mesh with gmsh that wasn't good.
Hr_kules is offline   Reply With Quote
Old   February 21, 2023, 05:04
M
AtoHM is on a distinguished road
Only thing that sticks out to me is that you sometimes use insidePoint and sometimes use inside for cellZoneInside.
Honestly, I never used insidePoint and do not know what purpose it serves as inside worked fine in any case I meshed. Could be a thing relating to ESI/Foundation divergence?
AtoHM is offline   Reply With Quote
[OpenFOAM] Error !! No. of points and fields don't match mkjmalik ParaView 4 November 2, 2019 10:37
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[Other] mergeMatchPairs with arcs vainilreb OpenFOAM Meshing & Mesh Conversion 1 August 5, 2013 08:11
[snappyHexMesh] Pure hex mesh with snappy alf23 OpenFOAM Meshing & Mesh Conversion 17 February 17, 2013 14:24
[snappyHexMesh] Snappy Hex Mesh problems likefry OpenFOAM Meshing & Mesh Conversion 3 September 22, 2011 06:49
