[Technical] Flow between two cylinders - OpenFoam 10 - dynamic mesh
Old   February 16, 2023, 03:47
Default Flow between two cylinders - OpenFoam 10 - dynamic mesh
npb
npb is on a distinguished road
Hi!
Do you know if there is any tutorial about flow between two coaxial cylinders (the inner cylinder to rotate and the outer cylinder to be fixed) using dynamic mesh for OpenFoam 10?
I tried to simulate this, but I have problems with the NCC - how to define only the inner cylinder to rotate or how to chose a right zone to create the NCC? I create the baffles which are close to the inner cylinder, split them, then createNonConformalCouples, but it does not seem to lead to any reasonable results. I place the BC for the nonCouple in 0/p and 0/U, but openFoam wants also BCs for nonConformalCyclic_on_nonCouple1, nonConformalCyclic_on_nonCouple2, nonConformalError_on_nonCouple1 and nonConformalError_on_nonCouple2, which is not ok, maybe.
I found a template, in OpenFoam, but in this case I have problems with some defaultPatch { name background; type internal;}, which present in the blockMeshDict file. The openFoam requires then some boundary conditions for this background and I am not very sure what they should be (since they are type internal).
I should mention that I tried using blockMesh alone or snappyHexMesh. But I have the same problems in both cases...
Could someone help with this?
Thank you very much!
npb is offline   Reply With Quote
Old   February 19, 2023, 04:34
M
AtoHM is on a distinguished road
May I ask, are you sure you need an NCC interface and different regions to model "flow between two coaxial cylinders"? Maybe your model looks different than I imagine, maybe you can elaborate on that?
AtoHM is offline   Reply With Quote
Old   February 19, 2023, 09:32
npb
Thank you for your reply! I just want to test it with such simple model.
unable to run dynamic mesh(6dof) and wave UDF shedo Fluent UDF and Scheme Programming 0 July 1, 2022 17:22
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
dynamic mesh in openfoam cctv OpenFOAM Running, Solving & CFD 0 March 19, 2014 02:04
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
How to Us Dynamic Mesh in OpenFOAM lzgwhy OpenFOAM Programming & Development 4 November 6, 2009 05:18
