[snappyHexMesh] Defining separate objects as a region in an STL file at once
Old   September 29, 2023, 01:36
Post Defining separate objects as a region in an STL file at once
george
scfd is on a distinguished road
I'm seeking a way to define regions for multiple bodies within a single STL file simultaneously. When I mesh geometries like the one shown in fig-1 using snappyHexMesh, I encounter difficulties in defining inner coordinates (locationsInMesh). When there are a large number of objects (more than 100) that need to be defined, manually writing coordinates becomes frustrating because I have to identify the inner coordinates for each separate object in the STL file before adding them to the snappy dictionary. When I provide only one coordinate, it creates a region exclusively for that specific object or part.
locationsInMesh
        ((x0 y0 z0) fluid_region)
	(( x1 y1 z1) solid_region_1)
	(( xn yn zn) solid_region_1)
	(( x1 y1 z1) solid_region_2)
	(( xn yn zn) solid_region_2)
Is there an easy way to capture all separate objects as region with snappyHexMesh?
regards,
scfd
scfd is offline   Reply With Quote
Old   September 29, 2023, 03:34
M
AtoHM is on a distinguished road
AFAIK there is no possibility to just mesh every region. That would be a great feature, though.
AtoHM is offline   Reply With Quote
seperate, snappyhexmesh, stl
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
