[mesh manipulation] How to handle extra domain creation from splitMeshRegions?
Like Tree1Likes
  • 1 Post By kazamiac
Old   March 31, 2021, 06:10
Default How to handle extra domain creation from splitMeshRegions?
Sunag R A
sunagra27 is on a distinguished road
Dear All,
I have created a stl mesh using open3D from point cloud. This mesh was split into two domains as a patch and then added back using "surfaceAdd". Now, this mesh is implemented into snappyHexMeshDict.
I mesh is running well. But, when I do splitMeshRegion after some topoSet addition, it creates multiple domains, where my cellZoneRegion has only two regions and I need only these two regions.
The multiple domains has only one 1 cell in it. How to handle those.? Can it be addressed somehow in ChangeDictionary (Since I am doing chtMultiRegionSimpleFoam). Or the only way is to change the mesh itself?
Below is the snippet of splitMeshRegion.
Region Cells
0 457997
1 241
2 1
3 1
4 1
Region Zone Name
0 1 gland
1 0 tumor
2 -1 domain2
3 -1 domain3
4 -1 domain4
Any leads will be appreciated.
Regards,
Sunag R A.
sunagra27 is offline   Reply With Quote
Old   March 7, 2023, 05:23
Default Any solution?
Atefeh T
Atefeh T is on a distinguished road
did you find a solution for this problem? I also get an extra region when I use the command splitMeshRegions -cellZones -overwrite , it says that it is a dummy file but when I want to run the simulation, openfoam asks for the information of the polymesh of this region which I dont want and I dont care!
BTW I should say that I use blockMesh and then snappyHexMesh -overwrite so my theory is that this extra region is probably related to the blockMesh region that is created initially which I want to get rid of for my simulation at the end.
Can anybody help me with this problem? how should I get rid of this extra region?!
Thank you in advance
Atefeh T is offline   Reply With Quote
Old   November 28, 2023, 16:58
Dimitris
kazamiac is on a distinguished road
try splitMeshRegions -cellZonesOnly. it worked for me.
Ron71 likes this.
kazamiac is offline   Reply With Quote
mesh 3d, openfoam, snappyhexmesh, splitmeshregions
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Sudden increase the residual of Maxwell's equations hsezsz CFX 2 October 13, 2016 06:58
Different diffusivity for additional variable in Fluid and porous domain ftab CFX 4 June 27, 2012 13:03
Creation of Fluid Domain mehduri Main CFD Forum 0 September 21, 2003 00:34
