[Commercial meshers] Matching Mesh Size at Interfaces in a Merged Mesh |
January 24, 2024, 16:38 |
dramesh
Hello all,
I have a geometry that I split into 5 different regions. I created a hexahedral mesh in Ansys Meshing for each of these parts, then used the OpenFOAM mergeMesh utility to stitch the mesh together into one body. This merged body looks good except for one issue: the difference in mesh size between one region and another is too large at certain interfaces. I would like to ensure a size ratio of ~10% between neighboring cells. Is there a way I can achieve this using snappyHexMesh or a different meshing tool without risking the creation of non-hexahedral elements (my mesh needs to be purely hex)? Thank you! Last edited by dramesh; January 24, 2024 at 23:17. |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
