[blockMesh] Please helpme with this problem
Like Tree2Likes
  • 1 Post By arezayan87
  • 1 Post By John Philip
Old   March 24, 2024, 06:43
Default Please helpme with this problem
John Philip
John Philip is on a distinguished road
Below is my code
| \\ / O peration | Version: v2312 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
scale 1;
vertices
(0 0 0) //0
(10 0 0) //1
(14 0 0) //2
(24 0 0) //3
(24 4 0) //4
(0 4 0) //5
(0 0 1) //6
(10 0 1) //7
(14 0 1) //8
(24 0 1) //9
(24 4 1) //10
(0 4 1) //11
blocks
//hex (0 1 2 3 4 5 6 7 8 9 10, 11) (20 20 1) simpleGrading (1 1 1)
edges
( arc 1 2 (12 2 0)
arc 7 8 (12 2 1)
boundary
/*movingWall
type wall;
faces
(3 7 6 2)
fixedWalls
type wall;
faces
(0 4 7 3)
(2 6 5 1)
(1 5 4 0)
frontAndBack
type empty;
faces
(0 3 2 1)
(4 5 6 7)
John Philip is offline   Reply With Quote
Old   March 24, 2024, 14:19
Default check your vertex locations
Amirreza
arezayan87 is on a distinguished road
Hi dear
Your blockMeshDict file is not correct and lots of errors exist. I solved the errors and generate your desired geometry but the boundaries and spacing might not be ideal and you should revise them based on your problem.
The attachment can be implemented correctly but as I mentioned before, boundaries should be defined properly.
best regards
Amirreza
File Type: zip blockMeshDict.zip (767 Bytes, 2 views)
John Philip likes this.
arezayan87 is offline   Reply With Quote
Old   March 25, 2024, 03:54
Default Thank you
John Philip
Thank you
arezayan87 likes this.
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
