[Other] wedge geometry from rectangular domain using extrudeMesh |
April 18, 2024, 12:54 |
Carmelo Baronetto
Rep Power: 2 |
Good morning to all,
I hope you can help me with this problem. I want to create a wedge geometry to simulate a portion of a cylinder. The mesh requires a local cylindrical refinement. I followed these steps: 1) I created a rectagular domain using blockMesh. I set boundary types in the blockMeshDict for all patches. 2) I locally refined using topoSet and refineMesh 3) Finally I extruded the mesh using extrudeMesh, which generates a wedge of 5 degrees. The geometry looks fine but I guess there are some issues with boundaries. All the boundaries set in blockMeshDict are still present in the wedge geometry, except for the lower side of the rectagular which is now the axis of the cylinder. I guess no boundary condition has to be set fo this face but I don't know how to manage it. In this case, I didn't specify any boundary conditions and it is set as empty by default (as it is expected). If I simply cancel that boundary in the boundary.C, checkMesh returns an error. Code:
*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2312 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; arch "LSB;label=32;scalar=64"; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 7 ( inlet { type patch; nFaces 16; startFace 128270; } confine_sup { type patch; nFaces 100; startFace 128286; } confine_dx { type patch; nFaces 30; startFace 128386; } wall_domain { type wall; inGroups 1(wall); nFaces 104; startFace 128416; } side_zero { type wedge; inGroups 1(wedge); nFaces 64200; startFace 128520; } side_pos { type wedge; inGroups 1(wedge); nFaces 64200; startFace 192720; } defaultFaces { type empty; inGroups 1(empty); nFaces 700; startFace 256920; } ) Thank you |
How to mesh a domain around a rounded geometry with structured grid | quarkz | Pointwise & Gridgen | 2 | March 5, 2019 22:05 |
Sudden increase the residual of Maxwell's equations | hsezsz | CFX | 2 | October 13, 2016 06:58 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Problem with building geometry - concentric cylinders | Rhoddwen | OpenFOAM Pre-Processing | 9 | December 17, 2014 10:02 |
block geometry inside fluid domain | jeff | Main CFD Forum | 18 | April 12, 2004 11:37 |
