[snappyHexMesh] SnappyHexMeshDict setup Problem
Old   February 18, 2009, 11:45
Default SnappyHexMeshDict setup Problem
jakob Huettmeyer
jakoff is on a distinguished road
This is probably an easy question for anyone already using snappy for a while but after searching the Forum for quite a while and trying to solve the problem by myself i'm asking for your help!
I want to use snappyHexMesh for the first time and tried to adapt and understand the motorBike tutorial but when I start snappy I get the error:
"meshQualityControls is undefined in dictionary"
and it stops.
I used the meshQuality Options down in the snappyHexMeshDict from the motorBike tutorial. Do I need a file with additional parameters or how can I solve this issue?
Hopefully someone can give me a hint what to do.
Thanks
jakoff is offline   Reply With Quote
Old   February 19, 2009, 02:57
Default hi, no our don't need any f
Wolfgang Heydlauff
wolle1982 will become famous soon enough
hi,
no our don't need any further file. "is undefined" very often means that before the entry (here meshQualityControls) there is something missing, that completes the routine before.
e.g.: a ";", ")", "}" .....mostly the ";"
please check that. or post your snappyHexMeshDict here.
wolle1982 is offline   Reply With Quote
Old   February 20, 2009, 03:29
Default Hi Jakob, it is very clear
Wolfgang Heydlauff
Hi Jakob,
it is very clear what goes wrong:
you made the initial mesh with blockMesh and then inserted a STL file of a cube AND you defined a refinementRegion (here: a searchableBox). this is not necessary. refinementRegions (boxes and spheres) define refinement regions in ADDITION to the refined geometry. very needful to refine like wake-region (Nachlauf) behind a car or a wing.
but you only want to refine around your cube, so get rid of the refinementRegion and you'll be fine, see: you defined "outside" of the box, which means that sHM refines EVERYTHING outside this box. here: it refines 5 times. your cube only is refined 3 times, thats why you cannot see it. The refinement level is always referred to global Mesh cell-size, not to local cell-size.
another possibility for you to refine only a stupid box is to get rid of your STL file and only define a searchable box with mode "inside". pay attention to locate your locationInMesh-Point outside this box (in both cases). sHM then refines the initial Mesh in such a way, that inside your searchable box the given refinementlevel (5) is homogeneously reached. the locationInMesh-Point tells sHM to keep all cells outside the box and deletes the cells inside the box. so, the result is the same. disadvantage: works only for boxes and spheres.
Old   February 20, 2009, 06:11
Default Thank you Wolfgang, your ex
jakob Huettmeyer
Thank you Wolfgang,
your explanations made things a lot better to understand for me.
I found my mistake and I could have had everything running already, but my stl file was corrupted. So thats why it didn't work.
A couple of weeks and I might even get it running ;)
Old   March 4, 2009, 11:11
Default Hi Foamers, I have a proble
Steven Darkes
stevendarkes is on a distinguished road
Hi Foamers,
I have a problem with snappyHexMesh. I would like to mesh a simple case on one processor but OF is always looking for decomposeParDict!
Any idea where I have to specify that I want to run it on one processor?
Thank's in advance!
stevendarkes is offline   Reply With Quote
Old   March 4, 2009, 11:19
Default Hi Steven, copy the decompo
norman1981's Avatar
Norman Del Puppo
norman1981 is on a distinguished road
Hi Steven,
copy the decomposeParDict file taken from the motorBike tutorial case in your system directory and modify it in this way:
numberOfSubdomains 1;
method hierarchical;
hierarchicalCoeffs
n (1 1 1);
delta 0.001;
order xyz;
Regards
Norman
norman1981 is offline   Reply With Quote
Old   March 4, 2009, 11:49
Default ADD-ON to Norman, it totall
Wolfgang Heydlauff
ADD-ON to Norman,
it totally doesn't matter how many domains are defined in the decomposeParDict. It's just necessary that there is one at all.
greetings.
Old   June 29, 2009, 09:26
Bob
Bob De Clercq
Bob is on a distinguished road
Dear,
I would like to continue on this thread as it is related to my problem.
To learn using snappyHexMesh I want to mesh the surface of a sphere. In addition to this, in order to model the wake behind the sphere, I define a block as refinementRegion.
When I do this, sHM does refine the sphere's surface but not the region of the block. As long as the sphere resides in the block's region, no refinement of the block is obtained. Once the block is moved away from the sphere it does work though.
According to the manual this should be possible, but I do miss something. Does anyone experienced this before? Below, I included the castellatedMeshControls; hopefully, the error is trivial:-)...
Many thanks,
Regards,
Bob
geometry
box
type searchableBox;
min (3.5 1.5 3.5);
max (20 -1.5 6.5);
ball.stl
type triSurfaceMesh;
name ball;
// Settings for the castellatedMesh generation.
maxLocalCells 1000000;
maxGlobalCells 2000000;
minRefinementCells 10;
nCellsBetweenLevels 3;
features
refinementSurfaces
ball
// Surface-wise min and max refinement level
level (2 2);
resolveFeatureAngle 30;
refinementRegions
box
mode inside;
levels ((1 1));
locationInMesh (2.1 2.1 3.6);
Bob is offline   Reply With Quote
setup vof test problem Fang Jin FLUENT 1 June 14, 2005 08:27
Dynamic Mesh setup problem Jim FLUENT 1 June 8, 2005 09:26
Problem Setup: Bi-Axial Rotation Possible? Harmeet CFX 6 February 11, 2005 15:27
CFD problem setup for flow through porous media Paresh Jain CFX 5 June 30, 2003 03:50
CFD problem Setup for Packed Bed Column Vijay CFX 0 June 20, 2003 08:23
