[snappyHexMesh] SnappyHexMesh snapping on stlfile fails
Old   October 29, 2008, 10:12
Default SnappyHexMesh snapping on stlfile fails
Julius
juliuslein is on a distinguished road
Hello together,
I'm trying to generate a mesh with snappyHexMesh on a simple ship shape. I already did the example with the igloo and one simple example with a *.stl - ball in the middle of block. Snapping worked fine only the boundary layer not.
Now I'm importing a simple hull as a stl-file. Refining works good but it does not snap properly. The only difference to the other examples is that I used distance in "refinementSurfaces" toolbox.
I attached the foto of before and after "snapping", the snappyHexMeshDict and the wigley.stl.
snappyHexMeshDict
wigleyHalf.stl.tar.gz
Hopefully someone of you can help me with this because I'm already quite desesperated...
Thanks in advance,
Regards, Julius
juliuslein is offline   Reply With Quote
Old   February 19, 2009, 09:05
Default try to turn up the values of
Wolfgang Heydlauff
wolle1982 will become famous soon enough
"nSmoothPatch"
"nSolveIter"
"nRelaxIter"
and turn down
"tolerance"
under "snapControls"
wolle1982 is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh with local refinement of ONE STLfile wolle1982 OpenFOAM Meshing & Mesh Conversion 31 May 14, 2020 10:57
[snappyHexMesh] snappyHexMesh not snapping to cylinder end wildfire230 OpenFOAM Meshing & Mesh Conversion 0 March 1, 2019 12:09
[snappyHexMesh] snappyHexMesh inclinced surface snapping problem Swift OpenFOAM Meshing & Mesh Conversion 19 January 18, 2017 04:42
[snappyHexMesh] SnappyHexMesh : snapping not matching surface Awak OpenFOAM Meshing & Mesh Conversion 4 May 31, 2016 08:23
[snappyHexMesh] SnappyHexMesh - snapping the wrong elements A.Wendy OpenFOAM Meshing & Mesh Conversion 1 September 25, 2012 03:52
