[snappyHexMesh] snappyHexMesh refinement issue
Old   October 9, 2019, 11:24
Default snappyHexMesh refinement issue
Najmiddin
najimaddin96 is on a distinguished road
Hi everyone, I am using SHM to mesh an stl file I generated. After running snappy I dont get the meshing I expected.
As you see in the picture below some cells are coarser than the others. I want all of it to be same
My snappyHexMeshDict is as below:
|  \\    /   O peration     | Version:  4.1                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       false;
geometry
    baffle03.stl
        type triSurfaceMesh;
        name baffle;
castellatedMeshControls
    maxLocalCells 300000;
    maxGlobalCells 5000000;
    minRefinementCells 0;
    maxLoadUnbalance 0.10;
    nCellsBetweenLevels 2;
    features
		file "baffle03.eMesh";
		level 5;
    refinementSurfaces
        baffle
            level (5 5);
            patchInfo
                type wall;
    resolveFeatureAngle 30;
    refinementRegions
    locationInMesh (0.001 -0.001 0.001);
    allowFreeStandingZoneFaces true;
snapControls
    nSmoothPatch 3;
    tolerance 2.0;
    nSolveIter 300;
    nRelaxIter 5;
        nFeatureSnapIter 10;
        implicitFeatureSnap true;
        explicitFeatureSnap false;
        multiRegionFeatureSnap false;
addLayersControls
    relativeSizes true;
    layers
    expansionRatio 1.0;
    finalLayerThickness 0.5;
    minThickness 0.2;
    nGrow 0;
    featureAngle 30;
    slipFeatureAngle 30;
    nRelaxIter 5;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedianAxisAngle 90;
    nBufferCellsNoExtrude 0;
    nLayerIter 50;
meshQualityControls
    maxNonOrtho 65;
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    maxConcave 80;
    minFlatness 0.5;
    minVol 1e-13;
    minTetQuality 1e-30;
    minArea -1;
    minTwist 0.02;
    minDeterminant 0.001;
    minFaceWeight 0.02;
    minVolRatio 0.01;
    minTriangleTwist -1;
    nSmoothScale 4;
    errorReduction 0.75;
writeFlags
    layerSets
mergeTolerance 1e-6;
najimaddin96 is offline   Reply With Quote
Old   October 14, 2019, 23:16
raphael
rapoutin is on a distinguished road
Can you send the checkMesh result?
and the snappyHexMesh log files?
It may be due to maxGlobalCells or maxLocalCells
rapoutin is offline   Reply With Quote
Old   October 15, 2019, 03:58
Damian Berghof
virengos will become famous soon enough
The refinement and quality of the mesh and required wall resolution are strongly related to your simulation task and chosen model. Which physical problem do you want to simulate?
best,
Damian
Get more support about Meshing with Salome and Visualization with ParaView in my growing groups
https://bit.ly/2lFfDkQ
https://bit.ly/2k2u8Pj
virengos is offline   Reply With Quote
Old   October 15, 2019, 08:51
Thomas Sprich
Swift is on a distinguished road
To refine the entire region add:
baffle
            mode        inside;
            levels      ((1E15 5));
to refinementRegions assuming you haven't hit the maxGlobalCells and maxLocalCells limits mentioned by rapoutin.
Thomas
Swift is offline   Reply With Quote
Old   November 9, 2019, 12:34
Najmiddin
Hi everyone, thanks so much for the replies and sorry for the late reply. @rapoufin, @virengos, @swift, I solved my problem by increasing nCellsbetweenLevels value to 9. The mesh got better, but my geometry had ~30million cells. For the same base mesh, I tried a different design, and surprisingly even with low nCellsbetweenLevels value, I get better mesh with less number of cells. Swift thank you for your recommendation, I will try it as soon as I will have to try new mesh. And by the way I @virengos, I am analyzing water flow inside a contact tank and use simpleFoam.
Best,
Nazhmiddin
[snappyHexMesh] SnappyHexMesh Problem 96faizizzuddin OpenFOAM Meshing & Mesh Conversion 10 October 10, 2022 06:45
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[snappyHexMesh] snappyHexMesh Parallel bad size error andrewpomeroy OpenFOAM Meshing & Mesh Conversion 2 April 2, 2018 01:08
[snappyHexMesh] snappyHexMesh issue kinbean OpenFOAM Meshing & Mesh Conversion 0 June 11, 2017 07:01
[snappyHexMesh] Problem with snappyhexMesh: modelling a pore chamber and pore throat model Saideep OpenFOAM Meshing & Mesh Conversion 5 May 10, 2015 14:46
