[mesh manipulation] Doesnbt have neighbor cells
Old   July 15, 2008, 23:19
Default Doesnbt have neighbor cells
weihong yao
ivanyao is on a distinguished road
hi
when i simulation a cube 6*6*6,i define the bottom (0 1 2 3),when i excute the blockmesh and it show bottom (0 1 2 3)doesn't have neighbor cells.my blockmesh.file follow:
arguments "/home/ivan/OpenFOAM/ivan-1.4/run/tutorials/rhoTurbFoam/building" off;
convertToMeters 1;
vertices
(-3 -3 0)
(3 -3 0)
(3 3 0)
(-3 3 0)
(-3 -3 6)
(3 -3 6)
(3 3 6)
(-3 3 6)
(-39 -3 0)
(-39 3 0)
(-39 -3 6)
(-39 3 6)
(153 -3 0)
(153 3 0)
(153 -3 6)
(153 3 6)
(-3 -60 0)
(3 -60 0)
(-3 -60 6)
(3 -60 6)
(-3 60 0)
(3 60 0)
(-3 60 6)
(3 60 6)
(-39 -60 0)
(153 -60 0)
(153 60 0)
(-39 60 0)
(-39 -60 6)
(153 -60 6)
(153 60 6)
(-39 60 6)
(-39 -60 60)
(153 -60 60)
(153 60 60)
(-39 60 60)
(-39 -3 60)
(-39 3 60)
(-3 -60 60)
(3 -60 60)
(153 -3 60)
(153 3 60)
(-3 60 60)
(3 60 60)
(-3 -3 60)
(3 -3 60)
(3 3 60)
(-3 3 60)
blocks
hex (24 16 0 8 28 18 4 10) (36 57 6) simpleGrading (1 1 1)
hex (28 18 4 10 32 38 44 36) (36 57 54) simpleGrading (1 1 1)
hex (16 17 1 0 18 19 5 4) (6 57 6) simpleGrading (1 1 1)
hex (18 19 5 4 38 39 45 44) (6 57 54) simpleGrading (1 1 1)
hex (17 25 12 1 19 29 14 5) (150 57 6) simpleGrading (1 1 1)
hex (19 29 14 5 39 33 40 45) (150 57 54) simpleGrading (1 1 1)
hex (1 12 13 2 5 14 15 6) (150 6 6) simpleGrading (1 1 1)
hex (5 14 15 6 45 40 41 46) (150 6 54) simpleGrading (1 1 1)
hex (2 13 26 21 6 15 30 23) (150 57 6) simpleGrading (1 1 1)
hex (6 15 30 23 46 41 34 43) (150 57 54) simpleGrading (1 1 1)
hex (3 2 21 20 7 6 23 22) (6 57 6) simpleGrading (1 1 1)
hex (7 6 23 22 47 46 43 42) (6 57 54) simpleGrading (1 1 1)
hex (9 3 20 27 11 7 22 31) (36 57 6) simpleGrading (1 1 1)
hex (11 7 22 31 37 47 42 35) (36 57 54) simpleGrading (1 1 1)
hex (8 0 3 9 10 4 7 11) (36 6 6) simpleGrading (1 1 1)
hex (10 4 7 11 36 44 47 37) (36 6 54) simpleGrading (1 1 1)
hex (4 5 6 7 44 45 46 47) (6 6 54) simpleGrading (1 1 1)
edges
patches
patch inlet
(27 9 11 31)
(37 11 31 35)
(9 8 10 11)
(11 10 36 37)
(8 24 28 10)
(10 28 32 36)
patch outlet
(25 12 14 29)
(29 14 40 33)
(12 13 15 14)
(14 15 41 40)
(13 26 30 15)
(15 30 34 41)
wall front
(0 3 7 4)
wall <back>
(1 2 6 5)
wall <left>
(0 1 5 4)
wall <right>
(2 3 7 6)
wall <top>
(4 5 6 7)
empty <wall>
(24 16 18 28)
(28 18 38 32)
(16 17 19 18)
(18 19 39 38)
(17 25 29 19)
(19 29 33 39)
(26 21 23 30)
(30 23 43 34)
(21 20 22 23)
(23 22 42 43)
(20 27 31 22)
(22 31 35 42)
(32 38 44 36)
(44 36 37 47)
(47 37 35 42)
(38 39 45 44)
(44 45 46 47)
(47 46 43 42)
(39 33 40 45)
(40 45 46 41)
(41 46 43 34)
(16 24 8 0)
(0 8 9 3)
(3 9 27 20)
(17 16 0 1)
(2 3 20 21)
(25 17 1 12)
(12 1 2 13)
(13 2 21 26)
wall <bottom>
(0 1 2 3)
mergePatchPairs
could anyone help me?
ivanyao is offline   Reply With Quote
Old   July 16, 2008, 06:49
Default Could you please post the erro
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Could you please post the error message from blockMesh?
Best regards
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   July 16, 2008, 21:14
Default hi sorry about that the err
weihong yao
hi
sorry about that
the error message is:
FOAM FATAL ERROR : face 0 in patch 8 does not have neighbour cell face: 4(0 1 2 3)#0 Foam::error::printStack(Foam:stream&)
#1 Foam::error::abort()
#2 Foam::polyMesh::facePatchFaceCells(Foam::List<foam ::face> const&, Foam::List<foam::list<int> > const&, Foam::List<foam::list<foam::face> > const&, int) const
#3 Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Field<foam::vector<double> > const&, Foam::List<foam::cellshape> const&, Foam::List<foam::list<foam::face> > const&, Foam::List<foam::word> const&, Foam::List<foam::word> const&, Foam::word const&, Foam::List<foam::word> const&)
#4 Foam::blockMesh::createTopology(Foam::IOdictionary &)
#5 Foam::blockMesh::blockMesh(Foam::IOdictionary&)
#6 main
#7 __libc_start_main
#8 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/i386/elf/start.S:122
From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 127.
FOAM aborting
Old   July 17, 2008, 04:17
Default Hi Weihong What you are tol
ngj
Hi Weihong
What you are told, is that the first face (face no. 0) in patch 8 is wrong. It could either be wrong orientation, but in your case, I cannot see any block which include all the points (0 1 2 3).
The specific patch which cause problems is the wall patch in the very bottom after the empty patches.
/ Niels
Why my code is ok with single processor but doesnbt work in openmpi xiuying OpenFOAM Running, Solving & CFD 0 November 23, 2007 13:44
Install doesnbt work hplum OpenFOAM Bugs 7 August 14, 2007 04:45
SonicFoam forwardStepTutorial doesnbt complete the run alberto OpenFOAM Bugs 1 June 10, 2007 15:35
RunFoamX doesnbt seem to be installed OpenFOAM 13 richmaes OpenFOAM Pre-Processing 1 January 24, 2007 02:55
[OpenFOAM] Paraview doesnbt show up kim ParaView 3 September 21, 2005 22:51
