[mesh manipulation] Stitch meshes with more two blocks
Old   July 3, 2006, 10:31
Default Stitch meshes with more two blocks
vantage1
vantage1 is on a distinguished road
I've got some troubles with the Stitch utility.
My case has several pairs of patches to joint. I 've got any problems with the first Stitch use, but the next delivers the following message:
--> FOAM FATAL ERROR : point, face or cell zone already exists
From function void addZones
const List<pointzone*>& pz,
const List<facezone*>& fz,
const List<cellzone*>& cz
Could somebody help me?
Miko.
vantage1 is offline   Reply With Quote
Old   January 27, 2010, 06:53
Default I have the same problem
Roger Jove
roger.jove is on a distinguished road
Hi Miko,
I may have the same problem. Did you ever solve it?
I have attached a picture that shows the type of mesh that I would like to create in order to preserve the orthogonality of the elements.
I have tried it using gambit and looked for any way to do it with blockMesh and stitchMesh but I haven't been able to success. Does anybody have an idea?
Thank you all!!!
Roger
roger.jove is offline   Reply With Quote
Old   March 11, 2010, 03:46
stephane sanchi
openfoam_user is on a distinguished road
Dear Miko,
dear Roger,
I am interesting in using the stitch command for meshes.
Roger have you find a way the stitch your different meshes ?
Best regards,
Stephane.
openfoam_user is offline   Reply With Quote
Old   March 12, 2010, 06:13
Roger Jove
Dear Stephane,
No, I could solve this problem using foam utilities. After that, I also tried to stitch the meshes using gambit but neither there I was able to solve it, and finally I abandoned my intentions because I was out of time.
By the way, I also left a post (for gambit) and was answered with some short indications. It may be useful to you.
check -> http://www.cfd-online.com/Forums/ans...tml#post243998
Finally, if you were to solve it, could you please upload it and post a comment with the instructions?
Roger
Old   March 12, 2010, 07:04
stephane sanchi
Hi Roger,
I am able to reproduce such a mesh (3 different blocks) with blockMeshDict.
So I do not use the stitchMesh command.
Hope it may help you a little bit.
Regards,
Stephane.
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface manuc OpenFOAM Meshing & Mesh Conversion 1 July 25, 2017 03:13
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
[blockMesh] How to merge blocks? Match, merge or stitch? gerritgroot OpenFOAM Meshing & Mesh Conversion 0 November 13, 2015 20:59
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 10:45
