[mesh manipulation] Boundary conditions transfert
Old   June 28, 2006, 08:20
Default Boundary conditions transfert
vantage1
vantage1 is on a distinguished road
I'm a new OF user and I have some troubles with merge applications of this CFDtool.
I would like to simulate a case with the SimpleFoam solver. My domain has two parts, the first one is a domain with a crude mesh and the second part is a domain with a higher quality of mesh. The purpose of my simulation is to laungh a kind of multi-block simulation that is to say to transfert fields results from the crude to the fine mesh. In addition to that these domains are create by CFX4. Here are steps what I did:
1. With CFX4, I create two meshes with a geo. extension.
2. With OpenFoam, I create a case in SimpleFoam for each domain, named "part1" and "part2", for instance.
3. In one of these case, I use the "mergemeshes" applications.
4.OpenFoam create a dorectory with new boundary conditions.
5. I copy the content of this directory in constant/PolyMesh (replacing old conditions).
6. I define type of patchs and corresponding fields. Given the transfert is operate between a patch 1 and a patch 2, their type are not very important, so I chose a wall patch type.
7. I use the stitchMerge application to operate the transfert with patch 1 for the slave patch and patch 2 for the master patch.
8. OpenFoam create an other one directory, named "1" in which there are new boundary conditions, particularly with a "meshmodifier" file.
Afterwards, I attempt two options:
9.1.I copy the content of "1" directory in constant/polymesh, but afterwrad all patch become empty type!!!!
or
9.2. I laungh the simulation specifying with a start time equal to the number "1".
In any cases, the simulation is done without merging domains!!!
Could anybody can help me for these issues???
Thanks
miko.
vantage1 is offline   Reply With Quote
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 04:39
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
