[Other] Problem when trying to generate a new mesh
Old   June 30, 2006, 07:51
Default Problem when trying to generate a new mesh
Gabriele Ottino
gaottino is on a distinguished road
I have a problem when I'm trying to generate a mesh. I created a file blockMeshDict, and then I write the command: blockMesh <root> <case>.
This is what is wrote in the shell window:
Reading block mesh description dictionary
Creating block mesh
Creating blockCorners
Creating curved edges
Creating blocks
Creating patches
Creating block mesh topology
Default patch type set to empty
Check block mesh topology
Basic statistics
Number of internal faces : 27
Number of boundary faces : 66
Number of defined boundary faces : 66
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating points
Creating cells
Creating patches
Creating mesh from block mesh
Creating merge patch pairs
Foam::error::printStack(Foam:stream&)
Foam::sigSegv::sigSegvHandler(int)
/lib64/tls/libc.so.6 [0x2aaaab9394c0]
blockMesh [0x428a3b]
__libc_start_main
__gxx_personality_v0
I suppose I do an error in creating the file blockMeshDict, but I don't know and I don't understand what kind of error.
Could someone help me,please?
Thanks a lot.
Best regards
gaottino is offline   Reply With Quote
mesh quality problem for displacementSBRStress motion solver zhaozhenkai OpenFOAM 0 January 22, 2017 11:02
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[ICEM] Problem with using the Delaunay volume mesh method manahara ANSYS Meshing & Geometry 12 December 25, 2014 21:54
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[ICEM] problem of Non-concidence mesh jeevankumarb ANSYS Meshing & Geometry 1 March 4, 2011 08:47
