[Other] Error during PitzDaily case
Old   April 5, 2014, 02:43
Exclamation Error during PitzDaily case
harshawardhank
harsha_kulkarni is on a distinguished road
Hello Friends
I am getting following error in pitzDaily case after entering blockMesh command.
--> FOAM FATAL IO ERROR:
attempt to read beyond EOF
file: /home/ict/OpenFOAM/pitzDaily/constant/polyMesh/blockMeshDict.boundary at line 87.
From function ITstream::read(token&)
in file db/IOstreams/Tstreams/ITstream.C at line 83.
FOAM exiting
harsha_kulkarni is offline   Reply With Quote
Old   April 11, 2014, 23:30
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
Hi
Did you resolve your issue?
This error says that there is something wrong in your blockMeshDict file.
Please attach the file if you need some help.
Best regards,
Fumiya
[Personal]
fumiya is offline   Reply With Quote
Old   April 12, 2014, 02:12
harshawardhank
Hello dear,
I got the issue, I did not put semicolon after face co-ordinate entries
Unphysical pressure field in LES PitzDaily tutorial case bling OpenFOAM Running, Solving & CFD 3 March 9, 2021 02:53
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 15:13
Reporting a bug in Allrun script on wingMotion case i.sabahi OpenFOAM Bugs 0 June 10, 2018 09:00
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Transient case running with a super computer microfin FLUENT 0 March 31, 2009 11:20
