[Commercial meshers] Hypermesh
Old   January 3, 2006, 09:00
Default Hypermesh
Guido Adriaensen
guido_adriaensen is on a distinguished road
Hello everybody,
Is it possible to read in a mesh generated by Hypermesh? Hypermesh is from Altair part of the hyperworks package.
I've tried several outputs, Among which Ideas and Ansys, but they do not work. They all give the same error:
--> FOAM FATAL ERROR : points deallocated
From function const pointField& polyMesh::allPoints() const
in file meshes/polyMesh/polyMesh.C at line 656.
FOAM aborting
Has anybody got an idea? If not I will contact hyperworks and ask them for different mesh outputs.
regards
Guido
guido_adriaensen is offline   Reply With Quote
Old   January 4, 2006, 14:49
Default The message comes from the mes
Mattijs Janssens
mattijs is on a distinguished road
The message comes from the mesh being empty so it looks like the conversion has failed.
The ideasToFoam was written some time ago to convert a mesh input file coming from Ansys. We only tested it on flange.ans from the laplacianFoam tutorial.
mattijs is offline   Reply With Quote
Old   January 13, 2006, 04:54
Default We managed to convert a hyperM
Mattijs Janssens
We managed to convert a hyperMesh file.
- export to Ansys
- if nessecary replace all DOS linefeeds with Unix ones (e.g. with dos2unix)
- use ideasToFoam
Old   January 13, 2006, 06:02
Default Hello Mattijs, Thanks for t
Guido Adriaensen
Hello Mattijs,
Thanks for the update. I also just received a message from hypermesh-people that it should work. I believe they have contacted you for this. :-) I just tested it myself and it works indeed, thanks for your help!
Guido
Old   March 17, 2006, 11:19
Default Hello Guido, Hello Mattjis, I
Vivek Kumar
vivekcfd is on a distinguished road
I tried to read an IDEAS file generated by ICEM
with ideasToFoam and I got exactly the same error message as Guido.
FOAM aborting
Aborted
I then executed dos2unix (since I generated the file on a windows machine) but still
no success. Can anybody help?
Regards and thanks
Vivek
vivekcfd is offline   Reply With Quote
Old   March 17, 2006, 13:23
Default - check the file for DOS linef
Mattijs Janssens
- check the file for DOS linefeeds.
- check the contents of the file. Compare to the flange.ans file in the laplacianFoam tutorial. Do you have 'N' (nodes), 'EN' (elements) and 'SFE' (boundary faces)? (all the other fields are discarded)
Old   March 20, 2006, 02:54
Default Hello, If you have created
Guido Adriaensen
If you have created the mesh with hypermesh you indeed will have to use something like dos2unix, since hypermesh writes out the mesh-files in dos-format.
I've spoken to some people from hypermesh last week. They are now working on a conversion from hypermesh directly to openFOAM. I've provided them with some examples of the mesh-files from openFOAM and they will create either a conversion tool or maybe even a direct export option inside hypermesh. The more people that ask hypermesh for a port to openfoam, the more likely that they will built it in to their next release.
kind regards
Guido
Old   March 20, 2006, 05:47
Default Mattijs: My IDEAS file diffe
Vivek Kumar
Mattijs:
My IDEAS file differ comopeletly from what lies in the .ans file from the laplacianFoam tutorial. I have checked my IDEAS file, it has no N, EN and SFE flags.
Guido:
I have not generated the IDEAS file with hypermesh but with another grid generation tool known as ICEM.
I am still not finding a way to export my mesh from ICEM to OpenFOAM. From ICEM, I can export my grid file to the follwoing unstructured grid formats:
ANSYS, ANSYS-CFX, IDEAS and PATRAN
Can you help?
regards
Vivek
Old   March 20, 2006, 08:21
Default export to fluent, you'll get a
nicolas
nico765 is on a distinguished road
export to fluent, you'll get a *.cas file. Then you can use fluentToFoam utility.
Nico
nico765 is offline   Reply With Quote
Old   March 20, 2006, 18:23
Default Nicolas As I wrote in my prev
Vivek Kumar
Nicolas
As I wrote in my previous mail, I can only export my mesh in the follwoing formats as per output module of ICEM:
Other exports require an additional ICEM license which I do not have at the moment.
Export to fluent: is it fluent_V4 or fluent_V6 export?
Can anyone give me a solution? I am getting very frustated with the very first step of getting aquianted with OpenFOAM.
thanks
VK
Old   March 21, 2006, 04:04
Default Try the Ansys format. See if i
  #11
Mattijs Janssens
Try the Ansys format. See if it is similar to that flange.ans one. If so try the ideasToFoam (in the new version it has been renamed to ansysToFoam)
Old   March 21, 2006, 04:11
Default Actually Mattijs, that one is
  #12
Hrvoje Jasak
Actually Mattijs, that one is very problematic: it reads the Ansys input file (creating vertices etc as an Ansys script) rather than the actual mesh. It came as a way of getting a mesh from Ideas and we didn't have a sensible export format. I'm not sure we've got a converter that can read the ansys mesh.
Hrv
Hrvoje Jasak
Old   January 14, 2008, 11:51
Default Hi all, which is the actual si
  #13
Francesco Boschetto
francesco_b is on a distinguished road
Hi all, which is the actual situation with Hypermesh? I tried to use ideasUnvToFoam to convert files but I still got some problems. Is there someone who succeeded in solving it?
Thank you in advance
Francesco
francesco_b is offline   Reply With Quote
Old   January 15, 2008, 03:34
Default Hello Francesco, I'm using
  #14
Guido Adriaensen
Hello Francesco,
I'm using Hypermesh to create my mesh-files and import them into OF. Which version are you using? We have had an update to write native fluent / star, etc formats. I'm using the fluent format, which I convert by using fluentMeshToFoam. This works perfectly. The problem with the current release is that they write nastran files, even though it says write fluent or whatever.
Guido Adriaensen
Old   January 15, 2008, 04:25
Default Hi Guido and Francesco, For
  #15
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
For the STAR-CD export, they're exporting Nastran solids as well. The boundary condition definitions are a bit of a hack: they define shells and then use the pro-STAR functionality to change these into boundary patches.
How are the boundary conditions being defined for the Fluent and unv outputs?
/mark
olesen is offline   Reply With Quote
Old   January 15, 2008, 04:30
Default Hi Guido, I've changed fro
  #16
Francesco Boschetto
Hi Guido,
I've changed from version 7.1 to 8.0 RS1 only some days ago, I also downloaded the patches from the Altair site, but I'm quite new to this version. I tried to export a mesh with the "CFD/general" template but I could only write a Nastran file. Where can I find your update? Is it available somewhere?
Francesco
Old   January 15, 2008, 05:19
Default Hi all! sounds good, that y
  #17
Florian Krause
florian_krause is on a distinguished road
Hi all!
sounds good, that you use HM for meshing
We have an CFD Update for HM80SR1 which should solve your problem.
ftp://ftp.altair.de/outgoing/hyperwo...80/CFD_Updates
You will find the packed files and a readme with the install introductions
In the Utility Browser you will get a CFD I/O menu where you can export a "real" Fluent *.cas file, so no problem to use fluentMeshToFoam ;)
a positive feedback would be nice!
Regards,
Flo
florian_krause is offline   Reply With Quote
Old   January 15, 2008, 05:27
Default Hello Francesco and Mark, W
  #18
Guido Adriaensen
We have had an update from Altair. If you send me an email I will send you the files, you need to extract them in your install directory of HW and it will create the correct translators. Or you could contact Altair and request this update from them, it was an unofficial update from the USA department of Altair.
kind regards
Guido Adriaensen
Old   January 15, 2008, 05:48
Default Hello, The update I was spe
  #19
Guido Adriaensen
The update I was speaking about is the same as the one from Florian. It works perfectly for us. :-)
kind regards
Guido
Old   January 15, 2008, 06:16
Default Hi, This patch is the actua
  #20
Florian Krause
This patch is the actual one, but it will be updatet from time to time.
So I can let you know if we have a new cfd update with significant changes on our ftp site...
Regards,
Flo
HyperMesh for Mesh Generation for SU-2 MM711 SU2 0 June 22, 2018 09:12
Hypermesh Exporting eishinsnsayshin FLUENT 8 November 29, 2012 00:29
Hypermesh Exporting eishinsnsayshin ANSYS 0 April 3, 2012 18:16
Hypermesh file to Fluent Logesh FLUENT 1 November 30, 2011 13:46
Volume mesh for Fluent.. Hypermesh or TGrid?? mayur FLUENT 5 June 25, 2010 01:45
