[Technical] What is the best option for create a mesh not using blockmesh
Old   January 16, 2008, 09:53
Default What is the best option for create a mesh not using blockmesh
Antonio Martins
titio is on a distinguished road
Send a message via MSN to titio Send a message via Skype™ to titio
I would like to know what is the best option for generate a mesh, without resorting to blockmesh. Is Gambit o.k?
I am asking this because FoamX, it seems, does not support the graphical generation of mesh. Is anyone aware of some extensions of OpenFOAM, or FoamX, that can be used.
Thanks,
Titio
titio is offline   Reply With Quote
Old   January 16, 2008, 11:43
Default Hi Titio, I tried Gmsh, Sa
Francesco Boschetto
francesco_b is on a distinguished road
Hi Titio,
I tried Gmsh, Salome and HyperMesh; good results with all of these, it also seems that Gambit works good. It depends on what you need to do, but I think Gambit is ok, you can experience also the other tool, let me know what you think about them
Best Regards
Francesco
francesco_b is offline   Reply With Quote
Old   January 16, 2008, 13:10
Default I have experience with gambit,
Frank Bos
lr103476 is on a distinguished road
I have experience with gambit, gridgen and gridpro. For complex 3D hex-meshes, you need to put a lot of different blocks in your domain, which is easiest with gridpro and hardest with gambit.....If you've got a simple (2D) comp domain, gambit works just fine.
Regards, Frank
Frank Bos
lr103476 is offline   Reply With Quote
Old   January 17, 2008, 02:00
Default Other commercial tools are, fo
Francesco Del Citto
fra76 is on a distinguished road
Other commercial tools are, for example, Tgrid (only volume mesh, you need a good surface mesh), Harpoon or Ansa.
All depends on your specific needs, habits and geometry!
Francesco
fra76 is offline   Reply With Quote
Old   January 17, 2008, 02:37
Default I recommened you to use HyperM
Florian Krause
florian_krause is on a distinguished road
I recommened you to use HyperMesh80SR1 with the actual CFD-Update of course I do...
You can send me an eMail when you are interested in further information regarding HM
Regards,
Flo
florian_krause is offline   Reply With Quote
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
error message cuteapathy CFX 14 March 20, 2012 06:45
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
