[snappyHexMesh] Mesh stl
Old   December 8, 2008, 05:02
Default Mesh stl
fabrizio
fabrizio is on a distinguished road
Hi dear fomers I have a question for you; I use SnappyHexMesh utility to simulate a wind tunnel application, starting from a stl geometry to create the cavity inside a mesh created with blockmesh. My question is the following: can I mesh the stl geometry with Snappy? Or can I extract the mesh only on stl surface?
Thank you very much for help
Fabrizio
fabrizio is offline   Reply With Quote
Old   December 9, 2008, 02:30
Default Hey Fab Yes thats the whole
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hey Fab
Yes thats the whole idea with snappyhexmesh.
It's actually not intended as a 2d mesh tool as far as I know. The userguide example is only in 2d for easier understanding. If you look at the two tutorials in the snappyhexmesh folder where yout tutorial files are located you will get a better idea of the approach.
For clarification the .stl file is actually a mesh or an interpretation of the surface using triangles so you have a surface mesh from which you build your internal/external mesh.
Regards Niels
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   December 9, 2008, 11:41
Default Hi Niels thanks to your sugges
fabrizio
Hi Niels thanks to your suggestion I can now obtain internal and external mesh, thank you! I only can't understand how to extract the pressure insisting on the surface of the stl geometry. Another question: I have to rebuild the mesh of the stl (so the internal mesh) in term of point and cells, but the 'cells' files I have in the OF directory is only a list of faces; I expected to find something like that:
hex(0 1 2 3 4 5 6 7), so a list of nodes
but I have this
hex(0 1 2 3 4 5) that is a list of faces.
Can you help me?
Thank you again
Fabrizio
Old   December 10, 2008, 02:30
Default Hey Fab I can try. :-) I
linnemann's Avatar
Niels Nielsen
Hey Fab
I can try. :-)
In order to have the pressure on a face you need to have that face as a separate patch on which you can do the pressure calculations.
To have a separate patch for that you need to split your .stl file into more "solids". Opening the .stl file with a text editor (only if its ASCII .stl) you will have the first line like so
solid somename_of_the_face
If you have exported the .stl as one geometry you will most likely only have one of these lines containing the solid line. You need to split your .stl into more solids and these solids can also be faces but not all cad programs support this.
When you have done this creating your mesh will create patches based on the names you have given each solid. Now you should be able to calculate the pressure on the wanted patch/face.
have a look at this description maybe it will help you further.
http://www.cfd-online.com/OpenFOAM_D...tml?1228743815
Regards Niels
Linnemann
Old   December 10, 2008, 04:06
Default Hi Niels I've tried with a sim
fabrizio
Hi Niels I've tried with a simple geometry and all went fine!
My problem is now that I can't mesh the stl of a complex geometry; I can obtain the cavity, but not the internal mesh of the geometry.
If you want I can send you my SnappyHexMeshDict and the stl file, so you can give a look.
Tell if you have time to spend for a quite new foam user...
Thank you again
Fabrizio
Old   December 10, 2008, 05:55
Default Hey Fab Unfortunately I don
linnemann's Avatar
Niels Nielsen
Hey Fab
Unfortunately I don't have time right now to look into your case.
I haven't used snappyhexmesh with both internal and external mesh at the same time only one of them, so I don't know how it behaves in such cases.
But you possibly have to search the forum about internal faces/patches I remember seeing something about that, but I don't have the link.
Regards Niels
Linnemann
Old   December 10, 2008, 05:59
Default Just reread the post you made
linnemann's Avatar
Niels Nielsen
Just reread the post you made and in order to get the internal mesh you have to place the point inside your geometry. If you place i outside snappyhexmesh will generate mesh outside your geometry.
Its this line you have to edit in SnappyHexMeshDict
locationInMesh (4.25 5.25 6.25);
This is in absolute x y z coordinates.
Hope this helps.
regards
Linnemann
Old   December 11, 2008, 03:50
Default Hi I've solved the problem abo
fabrizio
Hi I've solved the problem about inside/outside mesh, it was due to the axes origin I've considered...
My last problem is extracting pressure on the stl surface; I read the post you suggested and this is very useful for me, but I'm not allowed to modify the stl file. The problem is that I don't know what command/utility I have to use to extract pressure. I'd like now to try to calculate the pressure on a patch; infact in the boundary file I have a new patch of type wall created by SnappyHexMesh after it has build the mesh. Is it possible?
Thanks
Fabrizio
Old   February 16, 2009, 08:15
Default hi fabrizio , for extractin
Wolfgang Heydlauff
wolle1982 will become famous soon enough
hi fabrizio ,
for extracting the pressure on the surface you can use the "sample"-Tool (see other thread). therefor eyou must have the koordinates of the surface already.
wolle1982 is offline   Reply With Quote
Merging facets of STL volume mesh bidi ANSYS 1 December 23, 2016 00:46
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 16:59
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
ICEM 12 CFD help creating volume mesh from stl EmpError ANSYS 0 November 13, 2010 06:38
