[Commercial meshers] Tgrid tetra mehs with problems
Old   June 17, 2007, 14:16
Default Tgrid tetra mehs with problems
Fabian Braennstroem
braennstroem is on a distinguished road
I have a strange problem with a tetra mesh with prismen and a refinement region for a simple room airflow problem. I get:
Exec : fluentMeshToFoam /home/fab/OpenFOAM/fab-1.4/run/tutorials/simpleFoam Nottage_06_2007 Nottage_OB_ANSA_normaler_Durchmesser_Tetra_Refinem ent_Prismen_1_2.msh
Date : Jun 17 2007
Time : 20:07:12
Host : node1.ddorf.de
PID : 6347
Root : /home/fab/OpenFOAM/fab-1.4/run/tutorials/simpleFoam
Case : Nottage_06_2007
Nprocs : 1
Create time
Reading header: "TGrid 3D 4.1.3"
Found unknown block4
Embedded blocks in comment or unknown: (
Found end of section in unknown
Dimension of grid: 3
Number of points: 300035
number of faces: 2684605
Number of cells: 1273424
Found unknown block3010
@Embedded blocks in comment or unknown:�
Embedded blocks in comment or unknown:��
@33Embedded blocks in comment or unknown:@�
�]�@�Embedded blocks in comment or unknown:��
�ound end of section in unknown:?
�`@@�@33@Embedded blocks in comment or unknown:4�
Found end of section in unknown:�
Does anyone have an idea, what I can do? The mesh was written binary.
Regards!
Fabian
braennstroem is offline   Reply With Quote
Old   June 17, 2007, 14:32
Default Sorry, where is the error - I
Hrvoje Jasak
hjasak will become famous soon enough
Sorry, where is the error - I cannot see it. In any case, you will need to write the mesh ascii for the converter fo work.
There are known problems with the consistency of Fluent mesh and case files, which get cleaned up quietly when they go through Fluent. What makes it more difficult is that I didn't use Scheme to read the file when I wrote the converter in the first place.
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   June 18, 2007, 03:39
Default Hi Hrvoje, I thought, the e
Fabian Braennstroem
Hi Hrvoje,
I thought, the error is:
I will use an ascii mesh, thanks!
Regards!
Fabian
Benchmark Problems to test a new scheme for Convection-diffusion equation alibaig1991 Main CFD Forum 1 June 16, 2018 04:30
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 12:13
[TGrid] Tgrid hybrid mesh pyramid transition tony00 ANSYS Meshing & Geometry 4 November 26, 2009 04:36
HELP! TETRA and HEXA boundary sunlight007 Siemens 6 August 6, 2004 06:15
Some problems with Star CD Micha Siemens 0 August 6, 2003 13:55
