[blockMesh] 3d mesh for a pipe
Old   August 31, 2005, 13:53
Default 3d mesh for a pipe
Bei
tsjb00 is on a distinguished road
Hi. I build a 3D mesh to model a pipe with a injector in the center at the inlet. The orifice of the injector is much smaller than the pipe. I decompose the whole pipe into 8 wedge blocks(45 degree each) and mesh them in the same pattern. The desired mesh is of one layer of prism cells surrounding the centerline, followed by hexahedron cells.
While meshing the 45 degree arch, I notice that if I define many grid points, say 9 for 5 degree each, the mesh generated goes completely wrong. It also includes wedge cells and checkMesh complains about shared edges, skewness, almost every thing. But when I reduce the grid points to 1 or 2, the mesh is correct.
My question is:
1.In this case, does it mean only 1 or 2 cells is allowed for the degenerated edge/the arch? If so, should I decompose the pipe into more wedge blocks with smaller angle to get it right? Then 72 blocks are needed to get 5 degree angle. It seems too much for writing the mesh file.
2 Quite probably my approach is wrong in the first place. If 2d axis-symmetric modelling is not an option, please give me some suggestions on this.
Thanks a lot!
Bei
tsjb00 is offline   Reply With Quote
Old   January 30, 2009, 04:34
Default Hi Bei can u send bl
venkateshtl
Hi Bei
can u send blockmesh of injector pipe
Old   January 30, 2009, 04:40
Default Hi freinds i need O grid
venkateshtl
Hi
freinds i need O grid for NACA0012 please send me blockmesh.
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[blockMesh] generate a graded pipe mesh. jenright OpenFOAM Meshing & Mesh Conversion 0 August 22, 2009 08:58
