[blockMesh] Arcs in wedge case
Old   August 31, 2008, 07:36
Default Arcs in wedge case
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello World.
I'm stuck with a popular problem concerning nucleate boiling cases.
Simulation the boiling process with a constant inflow of gas into the problem domain trough an inlet-channel yields the following problem.
When the triple-contact line at the bottom of the problem geometry reaches the step of the inlet-channel the contact angle can't be calculated properly, because it can take no explicit value.
interFoam is computing complete crap after this exact moment.
It's a well know problem.
The solution is a small radius at this particular edge.
So, I have fumbled around with the blockMesh to get a radius into my wedge geometry.
But I have found no way of doing this so far.
Do you have any ideas how to get this working?
This is my blockMeshDict so far without a radius
blockMeshDict
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   September 20, 2008, 11:34
Default To make this a little bit more
sega's Avatar
Sebastian Gatzka
To make this a little bit more clear.
Here is a complete view of the desired geometry.
This kind of geometry is rather easy.
The harder part is the radius in this corner.
I'm currently struggeling to get a CAD-mesher working so I can import the CAD-model.
But is there a way to get this radius directy into the blockMeshDict (file is attached above)?
Greetings sega.
[Other] Wedge patch '*' is not planar LilumDaru OpenFOAM Meshing & Mesh Conversion 6 January 12, 2021 05:55
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
How to Initialise my LES case using my RANS case is there any utility for it ? Alhasan OpenFOAM Running, Solving & CFD 2 May 10, 2014 00:14
Error reading new case montag dp FLUENT 5 September 15, 2011 06:00
Axi-symmetric case gives wrong answer pbryant OpenFOAM Bugs 1 February 14, 2011 21:17
