[mesh manipulation] Generating nonuniform meshes with sizefunction
Like Tree1Likes
Old   April 12, 2006, 15:13
Default Generating nonuniform meshes with sizefunction
Alberto Passalacqua
Is it possible to generate non-uniform grids with nodes positioned following a distribution expressed by an analitical function?
Regards,
Alberto
Alberto Passalacqua
Old   April 12, 2006, 15:17
Default Yes. Generate a uniform mesh
Hrvoje Jasak
Yes. Generate a uniform mesh and then move the points :-)
Hrv
Hrvoje Jasak
Old   April 12, 2006, 15:19
Hrvoje Jasak
Hrv
Hrvoje Jasak
Old   April 12, 2006, 15:54
Default Do you mean with the moveMesh
Alberto Passalacqua
Do you mean with the moveMesh solver?
I gave a look, but it doesn't seem I can use a user defined function but only linear, quadratic and exponential (I need an hyperbolic tangent).
Alberto
Alberto Passalacqua
Old   April 12, 2006, 16:07
Default How about just doing a little
Hrvoje Jasak
How about just doing a little custom code like this:
pointField newPoints = mesh.points();
forAll (newPoints, i)
// Your code here, calculate the point position
mesh.movePoints(newPoints);
mesh.write();
Hrv
Hrvoje Jasak
Old   April 13, 2006, 05:40
Default Thanks Hrv. It works! :-)
Alberto Passalacqua
Alberto Passalacqua
Old   March 28, 2007, 05:43
Default Hi Alberto, Could you possi
Frank Bos
lr103476 is on a distinguished road
Hi Alberto,
Could you possibly give an example of how to move the internal points of a uniform mesh? (Just the few lines within the forAll(newPoints,i){} )
Thanks, Frank
Frank Bos
lr103476 is offline   Reply With Quote
Old   March 29, 2007, 14:49
Default Check your mail :-) A.
Alberto Passalacqua
Check your mail :-)
A.
Alberto Passalacqua
Old   December 23, 2007, 11:41
Default Hi I want to solve channel f
ehsan yasari
ehsanyasari is on a distinguished road
Hi
I want to solve channel flow with hyperbolic mesh in one direction. i am new in O-F, how can i generate hyperbolic mesh in O-F?
Regards
Thanks for your help
ehsanyasari is offline   Reply With Quote
Old   December 25, 2007, 19:14
Default Hello Ehsan, the trick is exa
Alberto Passalacqua
Hello Ehsan,
the trick is exactly the one explained by Hrvoje in this thread.
Create a uniform mesh, with the number of nodes you need in the three directions. Then write a small utility which:
- Reads the mesh (see how this is done in all solvers or mesh manipulation utilities).
- Does
mesh.write();
using an analytical expression to relate the position of a node in a uniform grid to the new position (this is commonly done to generate grids for channel flow simulations).
Regards,
Alberto
Alberto Passalacqua
Old   December 26, 2007, 07:09
Default Hello Alberto Thank you very
  #11
ehsan yasari
Hello Alberto
Thank you very much for your guide.
Could you possibly give your code? And tell me where should I add this code?
Excuse me for my basic question because I am new in O_F.
Best regards
Old   December 30, 2007, 13:02
Default hello Alberto Thank you very
  #12
ehsan yasari
hello Alberto
Thank you very much for your help,it works well.
Best Regards.
Old   December 31, 2007, 13:09
Default You're welcome :-) Happy ne
  #13
Alberto Passalacqua
You're welcome :-)
Happy new year,
Alberto
Alberto Passalacqua
Old   January 4, 2008, 10:56
Default Happw new year Alberto I am
  #14
ehsan yasari
I am going to run a channel395 with channel oodles solver, when i choose mixedsmagorinskey model and laplace filter, after some iteration, courant number diverged. but when i used simple filter it works,and also when i changed the mesh into uniform mesh, it works.
Do you have any idea about this problem?
Best Regards.
Old   January 8, 2008, 23:55
Default Hello Alberto, Thanks for y
  #15
vof_user
asaha is on a distinguished road
Hello Alberto,
Thanks for your hyperbolicSpacingChannel code. It works well with the given channel395 case.
Thanks.
asaha is offline   Reply With Quote
Old   July 15, 2009, 12:14
John Deas
johndeas is on a distinguished road
Hi, I would like to output the polyMesh in a new time directory. I tried to add
runTime++;
mesh.write();
Unfortunately, at runtime I get:
Requested field U does not exist in the database
    From function Foam::fieldAverage::initialise()
    in file fieldAverage/fieldAverage.C at line 108.
FOAM exiting
So how can I output in a new time directory, the same way renumberMesh or snappyHexMesh do ?
johndeas is offline   Reply With Quote
Old   July 15, 2009, 12:25
John Deas
To be more accurate, here is my new code
#include "argList.H"
#include "Time.H"
#include "polyMesh.H"
#include "transformField.H"
#include "fvMesh.H"
using namespace Foam;
//  Main program:
int main(int argc, char *argv[])
#   include "setRootCase.H"
#   include "createTime.H"
#   include "createMesh.H"
    pointField points=mesh.points();
    // Reading non-uniform grid parameters
    Info<< "Reading hyperbolicSpacingProperties\n" << endl;
    IOdictionary hyperbolicSpacingProperties
        IOobject
            "hyperbolicSpacingProperties",
            runTime.constant(),
            polyMesh::meshSubDir,
            runTime,
            IOobject::MUST_READ,
            IOobject::NO_WRITE,
            false
    Info<< "Reading A coefficient\n" << endl;
    dimensionedScalar A
        hyperbolicSpacingProperties.lookup("A")
    Info<< "A = " << A.value() << endl << endl;
    Info<< "Reading B coefficient\n" << endl;
    dimensionedScalar B
        hyperbolicSpacingProperties.lookup("B")
    Info<< "B = " << B.value() << endl << endl;
    // Adapting the grid
    points.replace(vector::Y, A.value()*points.component(vector::Y) +
                (1.0 - A.value())*(1.0 - Foam::tanh(B.value()*(1.0 -
                points.component(vector::Y)))/(Foam::tanh(B.value()))));
    // Setting the default precision of the points data to 10
    IOstream::defaultPrecision(10);
    mesh.movePoints(points);
    runTime++;
    mesh.write();
    //Writing points
    // Info << "Writing points into directory " << points.path() << nl << endl;
    // points.write();
    return(0);
It might be very naive, but I have still not completely grasped how data is organized in OpenFOAM.
Old   July 15, 2009, 13:35
Henrik Rusche
henrik is on a distinguished road
Dear John,
this error is not at all obvious ;-)
My bet is that you have a functionObject (fieldAverage to be precise) which I asking for U, but cannot find it.
Comment it and all will be fine - I hope
Henrik
henrik is offline   Reply With Quote
Old   July 15, 2009, 15:23
John Deas
I think one day I saw a piece of code which deactivated functionObjects, but I can not find it again. Do you see what I am refering to ?
-EDIT-
Just found it, it seems to be the
functionObjectlist::off()
method. I'll try this next time I have a grip on a work station.
tobiasS likes this.
Old   July 15, 2009, 15:37
Henrik Rusche
Dear John,
the keyword is "active_" ...
$FOAM_SRC/postProcessing/forces/lnInclude/forces.H
Henrik
[Other] Generating hex meshes STutexas OpenFOAM Meshing & Mesh Conversion 1 February 24, 2016 02:55
generating OpenFOAM meshes with pointwise robo OpenFOAM Pre-Processing 1 April 29, 2014 13:47
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 11:40
ParaView and Qt 4.3.5 on Mac OS X 10.6 Adrian OpenFOAM 3 August 8, 2010 03:16
Generating big meshes with GAMBIT on NT Andrew Ooi FLUENT 12 February 2, 2000 22:26
