[blockMesh] Simple face matching
Old   June 15, 2007, 13:04
Default Simple face matching
Anthony Costa
coastal593 is on a distinguished road
i have a pretty simple mesh, it's basically 2 2D blocks, and looks like ...
|aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa|
|bbbbbbbbbbbbbbb|cccccccccccccccccccc |
length(a) = length(b) + length(c)
there's a bit more to the geometry but that's the idea. all of the external faces are defined in one patch, and i leave the 3 internal faces alone (ignored from the patches list). blockmesh, so i'm told, should identify these and create a single internal face. it does not, i simply get,
--> FOAM Warning :
From function polyMesh::polyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 575
Found 3 undefined faces in mesh; adding to default patch.
thoughts?
coastal593 is offline   Reply With Quote
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
[ANSYS Meshing] Axis-symmetric sweep with inflation and face matching starki ANSYS Meshing & Geometry 0 May 23, 2018 00:17
Simulating fire in a tunnel luca1992 OpenFOAM 14 August 16, 2017 13:50
Simple model not matching calculated values Nick8529 FLUENT 0 July 1, 2017 10:09
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
