[blockMesh] BlockMesh amp Topology
Old   June 5, 2006, 01:09
Default BlockMesh amp Topology
Giuseppe Noviello
derath is on a distinguished road
Hi to all
I'm new user of O.F. and I've a problem.
I'm using blockMesh editor for create a simple model (in past i've used GMSH), but there is this error:
Exec : blockMesh /home/giuseppe/OpenFOAM/giuseppe-1.3/run/tutorials/simpleFoam
serra2
Date : Jun 05 2006
Time : 06:57:45
Host : linux
PID : 7701
Root : /home/giuseppe/OpenFOAM/giuseppe-1.3/run/tutorials/simpleFoam
Case : serra2
Nprocs : 1
Create time
Reading block mesh description dictionary
Creating block mesh
Creating blockCorners
Creating curved edges
Creating blocks
Creating patches
--> FOAM Warning :
From function bool Foam::blockMesh::patchLabelsOK(const label patchLabel, co
nst pointField& points, const faceList& patchFaces)
in file createTopology.C at line 116
patch 0 face 0 point label 9 larger than 7 the largest defined point label
--> FOAM Warning :
From function bool Foam::blockMesh::patchLabelsOK(const label patchLabel, co nst pointField& points, const faceList& patchFaces)
patch 0 face 0 point label 8 larger than 7 the largest defined point label
--> FOAM FATAL ERROR : Cannot create mesh due to errors in topology, exiting !
From function blockMesh::createTopology(IOdictionary& meshDescription)
in file createTopology.C at line 351.
FOAM exiting
certainly there is a error in my geometry but I don't know exactly where........
Thanks in advantage
Giuseppe
derath is offline   Reply With Quote
Old   June 7, 2006, 03:40
Default There is a -blockTopology argu
Mattijs Janssens
mattijs is on a distinguished road
There is a -blockTopology argument to blockMesh which will dump an .obj file. Load this into e.g. javaview or with objToVTK into Paraview (which both can display vertex numbers). Helped me a lot finding block errors.
mattijs is offline   Reply With Quote
[blockMesh] errors in topology while running 'blockMesh' shimakasaei OpenFOAM Meshing & Mesh Conversion 2 February 15, 2018 05:56
[blockMesh] blockMesh error - Negative Volume Block adoledin OpenFOAM Meshing & Mesh Conversion 2 June 22, 2016 10:44
[blockMesh] Error while running blockMesh Harak OpenFOAM Meshing & Mesh Conversion 0 December 11, 2014 09:36
[blockMesh] blockMesh crashes after "Check topology" sajad6 OpenFOAM Meshing & Mesh Conversion 1 November 1, 2014 14:50
[blockMesh] Sig11 on using 'tet' in blockMesh devlaam OpenFOAM Meshing & Mesh Conversion 2 October 17, 2013 16:29
