[blockMesh] Generating cellSets with blockMesh
Old   October 12, 2005, 16:28
Default Generating cellSets with blockMesh
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
File under: Solutions nobody asked for
Something missing from the original blockMesh (in my opinion) is the posibility to generate cell sets.
With some minor modifications to the original blockMesh (and the syntax of the dictionaries) I produced a utility that can do this.
The utility (and further descriptions) can be found at:
http://openfoamwiki.net/index.php/Contrib_blockMe shWithSets
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   October 13, 2005, 13:19
Default Nice one. Is it easy to modify
Mattijs Janssens
Nice one. Is it easy to modify so it writes cellZones instead (see polyMesh::addZones()) ?
(since zones are preserved across topology changes)
Old   October 14, 2005, 05:37
Default To be honest, I wasn't aware o
Assistant Moderator
Bernhard Gschaider
To be honest, I wasn't aware of the cellZones and I'm looking at the documentation. Is my impression correct, that cellZones are cellSets on steroids? In other words, what is the advantage of using cellSets (if there is any)?
But: Yes. It should be doable (I'll have a go at it next week, if I succeed I'll make a similar modification to the fluentMeshToFoam utility)
Old   October 14, 2005, 05:48
Default Cell zones will give you a uni
Hrvoje Jasak
hjasak will become famous soon enough
Cell zones will give you a unique decomposition of the mesh or a part of it: each cell will only below to zero or one cell zone. Also, there are facitilies to ask the cell which zone it belongs to (well, a bit different, but that's the idea). This is used a lot in topological mesh changes.
In cell sets, you can have several sets containing the same cell.
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   October 19, 2005, 11:26
Default I started to generate CellZone
Assistant Moderator
Bernhard Gschaider
I started to generate CellZones, but they were never added. When looking at polyMesh.C (method addZones) I found a fz.size() where in my opinion a cz.size() should be. My question: Is this a copy/past-typo or is there an interdependence between cell- and faceZones and this guards against cellZones being added without faceZones?`
The code in question:
// Cell zones
if (fz.size())
cellZones_.setSize(cz.size());
// Copy the zone pointers
forAll (cz, cI)
cellZones_.hook(cz[cI]);
cellZones_.writeOpt() = IOobject::AUTO_WRITE;
Old   October 19, 2005, 11:45
Default Looks like a typo. There is no
Mattijs Janssens
Looks like a typo. There is no special interdependence between cell and face zones at this level.
Old   October 19, 2005, 18:10
Default I thought so. To work around t
Assistant Moderator
Bernhard Gschaider
I thought so. To work around this the program creates a dummy faceZone of size 0.
The modified utility can be downloaded from the Wiki. In default mode it writes cellSets. If the switch -writeZones is used it writes cellZones instead (plus the dummy faceZone).
Also on the Wiki is a modified version of fluentMeshToFoam that behaves similar (-writeZones writes face- and cellZones instead of sets). This modification isn't completely tested.
Question: How do I visualize cellZones? The foamToVTK-utility generates data for faceZones, but not for cellZones.
Old   October 20, 2005, 05:09
Default There is no zone visualization
Mattijs Janssens
There is no zone visualization in foamToVTK. You can go from zone to set with faceSet (or setSet) and use source zoneToFace.
(You might want to have your blockMesh always write the cellSets, even when writing cellZones)
Old   October 20, 2005, 06:26
Default @foamToVTK: at least faceZones
Assistant Moderator
Bernhard Gschaider
@foamToVTK: at least faceZones get converted (like the patches)
@write both: my impression was, that if you have a region you don't need sets and I wanted to keep the amount of data writte to a minimum (not that it matters much).
[blockMesh] Generating blockMesh for modified Bubble Column dashsubhankar OpenFOAM Meshing & Mesh Conversion 1 December 29, 2017 04:17
[blockMesh] generating tetrhedral mesh using blockmesh pavan OpenFOAM Meshing & Mesh Conversion 0 January 9, 2012 22:21
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 11:40
[blockMesh] Generating a surface of revolution unsing blockMesh Rachit OpenFOAM Meshing & Mesh Conversion 0 June 23, 2011 03:39
ParaView and Qt 4.3.5 on Mac OS X 10.6 Adrian OpenFOAM 3 August 8, 2010 03:16
