[Gmsh] How to define these patches
Old   September 9, 2008, 05:48
Default How to define these patches
ZHOU Bin
Location: Nanjing/Torino, Nanjing/Piemente, China/Italy
zhoubinwx is on a distinguished road
Send a message via ICQ to zhoubinwx Send a message via MSN to zhoubinwx Send a message via Skype™ to zhoubinwx
Dear all,
First thank you for your attention.
I want to name the circle patches as "circle1","circle2",....
I write the following code:
For t In {1:101}
char add= (char) t;
Physical Surface(StrCat("circle",add)) = {e1[8+4*t]:e1[11+4*t]} ;
EndFor
When it is loaded, I get:
problem 1. add: unknown variable,
problem 2. I visualize the patch, and I could only get one patch named "circleadd", NOT "circle1".
If some of you have this experience, would you please give me any suggestions?
Thank you very much.
Bin
zhoubinwx is offline   Reply With Quote
Old   September 9, 2008, 08:50
Default Have a look at the BNS syntax
Martin Aunskjaer
aunola is on a distinguished road
Have a look at the BNS syntax of character expressions in Gmsh in section 2.1.2. It does not support a declaration like your 2nd line.
One suggestion is to simply replace what your are trying to do (convert t to a char and concatenate it with the string "circle") with the Sprintf() function. Have a look at the tutorial t8.geo in section 7.8 of the manual for an example of how this is done.
aunola is offline   Reply With Quote
Old   September 11, 2008, 03:20
Default Dear Martin, As you said, i
ZHOU Bin
Dear Martin,
As you said, it works now with the function "Sprintf()". Thank you.
Best regards,
Bin
Old   September 12, 2008, 07:45
Default Dear Martin and other friends,
ZHOU Bin
When I want to define the boundary condition for my circles in the file 0/U, for an example,
I tried many ways, but failed:
// for (int t=1;t<=101;t++)
// Sprintf("circle%g", t)
// "circle".merge(1:101);
// "circle".push_back(1)
// circle.merge(1)
"circle".append(1)
type slip;
I write here, just to see if some one knows how to define those patches: circle1, circle2, ... Not by hand. Otherwise it is a lot of work.
Thank you for your attention.
Bin
Old   September 12, 2008, 09:11
Default You are again using a syntax n
Martin Aunskjaer
You are again using a syntax not recognized by Gmsh. For instance, the C++ string push_back() function for appending characters to a string is unknown to the Gmsh parser.
To name your circle patches it should be possible to get through it using the Sprintf() function provided by Gmsh, though I haven't tried.
Old   September 12, 2008, 09:17
Default Ok, I see you have another pos
Martin Aunskjaer
Ok, I see you have another post about the same problem and have received some hlp there:
http://www.cfd-online.com/OpenFOAM_D...es/1/8536.html
Old   September 15, 2008, 08:52
Default Hi Martin, This problem is
ZHOU Bin
Hi Martin,
This problem is solved in the file 0/U and 0/p as the suggestions in the link.
I am implementing my boundary for those circles now, and I am sure to finish them soon.
Thank you.
Bin
Hydrogen storage by metal hydride longbk FLUENT 12 August 1, 2023 20:13
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 21:13
[mesh manipulation] Problem with using createPatchDict to define cyclic boundaries kaszt OpenFOAM Meshing & Mesh Conversion 0 April 1, 2016 21:18
UDF error for Heat Generation mame Fluent UDF and Scheme Programming 4 March 3, 2016 04:22
How to define patches after gmshToFoam ? seb_j OpenFOAM 8 July 13, 2011 09:25
