[Other] OpenFOAM workshop mesh handling and generation |
March 12, 2008, 06:13 |
Andrew Jackson
Dear All,
This is a reminder to anyone working in the area of OpenFOAM mesh generation, moving mesh or any other related meshing tasks. If they would like to present in the forthcoming "mesh handling and generation" session in the OpenFOAM workshop in Milan the closing date for a short a bstract on their work is the 31st March 2008. regards Andrew Jackson http://www.openfoamworkshop.org/08/i...itle=Main_Page |
March 18, 2008, 08:47 |
Hi Andrew,
I am preparing a
Vincent RIVOLA
Rep Power: 18 |
Hi Andrew,
I am preparing an abstract on high quality grid generation for OpenFOAM. Should I send it to you or somebody else? Regards, Vincent |
July 17, 2012, 07:43 |
disappearing internal wall after conversion
Hello All,
Just I am trying to work with OpenFoam and appears problem with internal wall. I used Centaur export mesh to fluent cas and convert this mesh in to OpenFOAM. Unfortunately , I lost a info subject internal wall. I believe that is some method for create a mesh included internal wall for OpenFOAM. I open for any suggestion, what kind of free tools should I use for proper mesh generating. I would like to setup a pressure wall drop on this internal wall before conversion into OpenFOAM ----------------------------------- | ~~~~~~~~:~~~~~~~ | | inlet ~~~~ :~~~~~~~ | outlet |~~~~~~~ ~:~~~~~~~ | ----------------------------------- : -- internal wall after conversion ----------------------------------- | ~~~~~~~~ ~~~~~~~| | inlet ~~~~ ~~~~~~~ | outlet |~~~~~~~~ ~~~~~~~ | ----------------------------------- P.S. I am a fresh OpenFOAM user and I am open for cooperation with OpenFOAM expert. Thanks and regards, Joe |
July 17, 2012, 12:34 |
Marco A. Turcios
Rep Power: 28 |
Do a search for threads about baffles, internal/zero thickness walls, and the createBaffles and mergeOrSplitBaffles utilities. That should give you a good start.
In a nutshell, you'll need to select the faces that used to be part of the internal wall and turn them into baffles. On a side note, please include screenshots or sketches in the future; the ASCII drawing you made is very difficult to see what you want, and the formatting on different browsers can cause it to appear distorted/different than you want. |
[snappyHexMesh] problems generating clean mesh | Christian_tt | OpenFOAM Meshing & Mesh Conversion | 2 | June 20, 2019 05:39 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 05:40 |
On body-fitted cartesian mesh generation | sbaffini | Main CFD Forum | 0 | October 21, 2016 10:32 |
OpenFOAM Training and Workshop Zagreb 2628Jan2006 | hjasak | OpenFOAM | 1 | February 2, 2006 21:07 |
