[blockMesh] CheckMesh error using a tutorial from OpenFOAM 114 with openFOAM 13
Old   January 14, 2008, 10:44
Default CheckMesh error using a tutorial from OpenFOAM 114 with openFOAM 13
Marta Pajon
martapajon is on a distinguished road
Dear all,
I am trying to run the tutorial 2.2 from OpenFOAM-1.4 guide (stress analysis of a plate with a hole),but I would need to run it with OpenFOAM1.3.
I have run BlockMesh and it seems to work, but it doesn't because Boundary and owner files are empty!!
When I run checkmesh the answer is something like:
Fatal error: Attempt to get back from at line 1681.
From function void Istream::getBack (token&t)
in file db/IOStreams/Iostreams/Istream.c at line 44.
FOAM existing.
Could you please tell me the reason of that? Is that related with that I am using 1.4.1 tutorials with openFOAM 1.3??
Thank you very much,
Marta
martapajon is offline   Reply With Quote
Old   January 14, 2008, 11:26
Default Hi Marta, I tested the bloc
Kati Laakkonen
kati is on a distinguished road
Hi Marta,
I tested the blockMeshDict from this tutorial with both 1.4.1 and 1.3, and it worked well, all files are written and checkMesh is fine. Did you change something in the blockMeshDict?
Regards,
Kati
kati is offline   Reply With Quote
Old   January 14, 2008, 11:59
Default Hi Kati!! Thank you for your
Marta Pajon
Hi Kati!!
Thank you for your answer.
I haven't done any change in the blockMeshDict. I just copy the tutorial in my user directory and I tried to run it.
I am cheking now if the copy was wrong,and maybe it was because I delete it and I am trying to copy it again and I am not able to copy boundary file, I do't know why.
Regards,
Marta
Old   January 14, 2008, 12:10
Default I managed to copy it again and
Marta Pajon
I managed to copy it again and after running it, not only boundary and owner appear empty as before, but faces and neighbour too.
Now the error with checkMesh is:
FOAM FATAL IO ERROR : Expected a '(' while reading VectorSpace<form,>, found on line 143 an error
file: ../plateHole/constant/polyMesh/points at line 143.
From function Istream::readBegin(const char*)
in file db/IOstreams/IOstreams/Istream.C at line 94.
FOAM exiting
Regards,
Marta
Old   January 14, 2008, 14:21
Default Hi Marta, I think checkMesh
Kati Laakkonen
Hi Marta,
I think checkMesh gives that error message because the file is empty. The error message from blockMesh would be more meaningful.
You might have a system related problem. Are you sure you have enough disc space, for example?
Regards,
Kati
Old   January 18, 2008, 06:19
Default Thank you Kati!!! I asked f
Marta Pajon
Thank you Kati!!!
I asked for more disc space and now it works. You were right.
Thanks a lot.
Marta
Old   January 18, 2008, 07:36
Default Hello everyone,and specially K
Marta Pajon
Hello everyone,and specially Kati,
To be able to run the tutorial form 1.4.1 version in 1.3 (the plateHole belonging to solidDisplacementFoam) I know I cant call GAMG solver so, which sover should I call to solve D and T?
which parameters are necessary to set within that solver?
As you can realize I am begineer in OpenFOAM and I am runing this case as an example to learn,practise and understand OpenFOAM.
I know this is not related with the mesh, but it is with the toturial form 1.4.1 run in 1.3.
Thank you!!!
Old   January 21, 2008, 12:52
Default Hi Marta, See the tutorials
Kati Laakkonen
Hi Marta,
See the tutorials in the 1.3 installation for guidance. You'll probably find a tutorial for the solver you are going to use (there was no solidDisplacementFoam in 1.3 so far I know). In stressedFoam plateHole example one uses ICCG, which needs as input only tolerance and relTol.
Regards,
Kati
fluxRequired OpenFoam Versions SimpleFoam Taylor Couette flow tutorial mörli OpenFOAM Running, Solving & CFD 0 April 9, 2019 11:50
[Tutorials] Coupling Dakota and OpenFOAM - Tutorial Tobi OpenFOAM Community Contributions 13 September 17, 2017 21:45
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 11:50
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 03:19
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
