[Technical] Mesh generation from dirty surface meshes
Old   December 9, 2007, 16:41
Default Mesh generation from dirty surface meshes
BastiL
bastil is on a distinguished road
I want to collect some ideas about my aim to run a case from which I only have dirty surface meshes. I do not have any geometry. Surface meshes represents geometry perfectly, however have free edges, overlappings,... From a commercial point of view this is good for surface wrapping or a tool like Harpoon. However, I want to use free software. Any ideas?
Gmsh could be possible: maybe convert into volumes and group them, mesh afterwards. However I do not know how to do. What oter ideas?
bastil is offline   Reply With Quote
Old   December 9, 2007, 21:19
Default Hi, Without knowing the det
Pei-Ying Hsieh
hsieh is on a distinguished road
Without knowing the details of your mesh, you can try tetgen. It can take surface mesh and generate a volume mesh from it.
pei
hsieh is offline   Reply With Quote
Old   December 10, 2007, 03:35
Default Or you can try SALOME www.salo
Ruben I. Mukhamadeev
benru is on a distinguished road
Or you can try SALOME www.salome-platform.org
benru is offline   Reply With Quote
Old   December 10, 2007, 05:46
Default Hi, both tools as far as I
BastiL
both tools as far as I know have the disadvantage that surface mesh has to be absolutely clean (no interesections, free edges,...) My surface mesh is dirty. I need to repair this e.g. by wrapping or performing boolean operations on surfacemesh not on geometry (!) or I need to reconstruct geometry...
Old   December 10, 2007, 05:53
Default Hm, to perform CAD cleaning as
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hm, to perform CAD cleaning as a prestep towards meshing.... that's tough. One tool would be ANSA, another Gambit, but both are commercial so... not good for you.
I saw that Blender is able to read iges file formats. I think it has boolean operations with different primitives, but when I asked on their discussion list if it is appropriate to use it as CAD clean software.... I got no answer (at least until now).
Dragos
dmoroian is offline   Reply With Quote
Old   December 10, 2007, 07:29
Default Hi, please read my requirem
BastiL
please read my requirements carefully: I do not have geometry, only dirty (intersecting, free edges,...) surface meshes from which I need to start volume meshing. Maybe one way would be to do geometry cleanup, however: Therefore a surface reconstruction is essential first.
Old   December 10, 2007, 10:31
Default Sorry, my bad! But still thos
dmoroian's Avatar
Dragos
Sorry, my bad!
But still those above should help you since they are able to read stl file formats too, and work with them.
Dragos
Old   December 10, 2007, 10:34
Default So Tetgen and Salome can perfo
BastiL
So Tetgen and Salome can perform boolean operations on surface meshes or do surface reconstruction? That are really good news...
Old   December 10, 2007, 10:48
Default You can also have a look to jc
tog
Guillaume Alleon
tog is on a distinguished road
You can also have a look to jcae (http://jcae.sf.net)
tog is offline   Reply With Quote
Old   December 10, 2007, 11:17
Default jcae does not seem to be able
BastiL
jcae does not seem to be able to do boolean operations on meshes or surface reconstruction, does it?
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] very bad quality snapped mesh federicabi OpenFOAM Meshing & Mesh Conversion 18 September 26, 2018 10:33
On body-fitted cartesian mesh generation sbaffini Main CFD Forum 0 October 21, 2016 10:32
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
