[mesh manipulation] MergeMeshes
Like Tree3Likes
  • 2 Post By elvis
  • 1 Post By nanavati
Old   May 18, 2006, 22:25
Default MergeMeshes
Pei-Ying Hsieh
hsieh is on a distinguished road
Dear OpenFOAM experts,
I am wondering about mergeMeshes utility and the sitichMeshes utility.
I am planning to "glue" two meshes together. In the OpenFOAM wiki site, the description of mergeMeshes if the following:
mergeMeshes adds the cells of two meshes together. It does NOT merge the faces between the two sets of cells. Neither does it check for overlapping cells.
To merge the faces use stitchMesh.
So, does it mean that I will perform
mergeMeshes <master> <master> <second> <sencond>
Followed by:
stitchMeshes <case> <case> <patch> <patch>
in stitchMeshes, does it "merge" the faces and also eliminate duplicate nodes?
Thanks in advance for your reply.
Pei
hsieh is offline   Reply With Quote
Old   September 10, 2014, 05:12
Pratik Nanavati
nanavati is on a distinguished road
Followed by:
Pei
Hi, Did you found any example on SticthMesh so far ?
Please let me know.
I am struggling for the same and unfortunatelly there is no exact complete StitchMesh Example available !!
nanavati is offline   Reply With Quote
Old   September 10, 2014, 07:32
Elvis
elvis will become famous soon enough
http://openfoamwiki.net/index.php/StitchMesh
http://openfoamwiki.net/index.php/Im...ith_interfaces
nanavati and Dave ZL like this.
elvis is offline   Reply With Quote
Old   September 10, 2014, 09:15
Pratik Nanavati
Thanks for the links.
In the Meanwhile, I have found one more complete tutorial.
http://www.tfd.chalmers.se/~hani/kur...eTutorials.pdf
Hope, this thread and these links will be helpful to those who are searching the stuff out there
Dave ZL likes this.
[Other] mergeMeshes in OpenFOAM extend nwpukaka OpenFOAM Meshing & Mesh Conversion 0 April 19, 2016 23:09
MergeMeshes with version OF14 jens_klostermann OpenFOAM Bugs 2 November 7, 2014 16:27
[mesh manipulation] MergeMeshes and stitchMesh problem flo OpenFOAM Meshing & Mesh Conversion 6 May 10, 2010 10:40
MergeMeshes and mesh format from 14x 15 pitmanm OpenFOAM Bugs 14 July 4, 2009 00:55
MergeMeshes fails on OF141 any fix hsieh OpenFOAM Bugs 3 January 29, 2008 19:31
