[Other] 2D unstructured mesh
Old   March 26, 2009, 03:19
Default 2D unstructured mesh
Majid Hojjat
majidhojjat is on a distinguished road
Hi!
Recently I am modeling a 2D problem using empty patches. Due to complexity of the geometry I can not use the "blockMesh" tool.
Has anybody some experience in importing 2D mesh to OpenFoam?
Previously I have used for 3D geometries, ICEM to produce unstructured mesh and FluentMeshToFoam to import it. That worked perfectly. but in 2D, there should be a single layer of elements in the third direction. I tried extruding a 2D mesh in ICEM, but then it was not possible to assign "part" name to the faces of the extruded mesh (because mesh is not a geometry object). So i had no boundaries (inlet, outlet, etc.) in OpenFoam.
Thanks!
majidhojjat is offline   Reply With Quote
Old   May 14, 2009, 17:09
Default Just import a 2D mesh into OF
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
You can just make a 2D mesh in say GAMBIT and export it as such. When importing into OF, the mesh will be changed into a 3D mesh with an empty front and back.
chegdan is offline   Reply With Quote
2d mesh unstructured icem
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] 2D profile unstructured mesh h3nn3 ANSYS Meshing & Geometry 2 June 17, 2015 10:09
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
