[Other] Viewing meshes
Old   May 27, 2009, 06:13
Default Viewing meshes
Terry Barnaby
terrybarnaby is on a distinguished road
I am trying to look at the mesh generated by snappyHexMesh in an effort to improve the mesh quality. Has anyone any suggestions on the best way to view the mesh for this purpose ?
At the moment I am using paraview 3.4. I generate a slice for viewing the mesh around my object in 2D. I currently have a simple, unrefined, cube based mesh. With this paraview displays the set of 2D squares in a grid but adds diagonals to each square. This makes it difficult to view what the mesh actually is especially when I start refining it with snappyHexMesh. Or am I doing something wrong with Paraview ?
terrybarnaby is offline   Reply With Quote
Old   May 28, 2009, 11:11
Assistant Moderator
Bernhard Gschaider
Originally Posted by terrybarnaby View Post
There's nothing wrong. As I understand it most algorithms in Paraview only work with hexaders and teraeders so if it encounters a general polyeder it breaks it down into tets. An that are the diagonals you're seeing
Bernhard
Old   May 29, 2009, 07:40
Terry Barnaby
Thanks for the info. I thought that might be the case. It does make if difficult to visualise the mesh though.
Does anyone know if there any other software that will provide a 3D display more suitable for viewing the mesh.
Mapping (interpolation) between two meshes Ebrahim OpenFOAM Programming & Development 2 June 15, 2020 13:31
How can I put the data of adpated meshes on the original unadapted meshes? xh110120 FLUENT 2 March 11, 2016 02:00
Hex and Tet meshes - simplefoam comparison danvica OpenFOAM Running, Solving & CFD 10 January 4, 2013 01:18
Viewing Meshes Abhijeet Vaidya Main CFD Forum 2 May 2, 2002 03:05
Large 3D tetrahedral meshes Aldo Bonfiglioli Main CFD Forum 4 August 27, 1999 03:33
