[snappyHexMesh] locationInMesh Error
Old   December 16, 2009, 13:42
Default locationInMesh Error
James Baker
fijinx is on a distinguished road
I am very new to openFoam and am just trying to get it running at this point. However, I keep getting the error:
Refinement phase
Point (-0.018 -0.018 -0.018) is not inside the mesh or on a face or edge.
Bounding box of the mesh-0.254 -0.762 -0.762) (1.778 0.762 0.762)
From function refinementParameters::findCells(const polyMesh&) const
in file autoHexMesh/autoHexMeshDriver/refinementParameters/refinementParameters.C at line 104.
FOAM exiting
. No matter if I choose a point inside the stl or outside (still within the bounding box) I get the same error. Any help is appreciated.
here is my setup which clearly shows the surface within the bounding box.
fijinx is offline   Reply With Quote
Old   December 16, 2009, 13:49
Anonymous
madad2005 is on a distinguished road
Have a look here:
http://www.cfd-online.com/Forums/ope...-mesh-but.html
I had the same issue and I finally resolved it by manipulating the order of my initial bounding box. Can't help you much more than that, I'm afraid.
madad2005 is offline   Reply With Quote
Old   December 16, 2009, 14:34
James Baker
Worked great, thank you!
Old   June 20, 2017, 14:30
Default same problem
ABHINAVMOHAN
abhinavmohan is on a distinguished road
convertToMeters 1;
vertices
(48 660 -2015) //0
(2000 660 -2015) //1
(2000 3000 -2015) //2
(48 3000 -2015) //3
(48 660 4000) //4
(2000 660 4000) //5
(2000 3000 4000) //6
(48 3000 4000) //7
blocks
hex (0 1 2 3 4 5 6 7) (20 8 8) simpleGrading (1 1 1)
edges
boundary
frontAndBack
type patch;
faces
(1 2 6 5)
(0 4 7 3)
inlet
type patch;
faces
(4 5 6 7)
outlet
type patch;
faces
(0 3 2 1)
lowerWall
type wall;
faces
(0 1 5 4)
upperWall
type patch;
faces
(3 7 6 2)
same problem can`t figure this out.
even though my STL file is in the box
abhinavmohan is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
